I cranked in some more timing.
chris142
SoCal
I have been running around 6btdc and the truck ran like a truck. But all you guys are saying 8-9 is better. So I loosened the pump and all the lines I could get to and cranked it up to about 9. My timing light is not that easy to read so I cant really tell if it's 8.5 or 8.7 or whatever.
Now When it starts it sounds like the 6.0L Powerjoke across the street. Much louder than it was. It also smokes much more, I could see my smoke in the headlights behind me. Get up and go seems worse, it does not want to rev past 3000 rpm.
The exhaust tone is much "rappier".
Thoughts?
bbjordan
Snow Monkey
Ashern Manitoba
I hate to answer a question with a question, but here goes:
How confident are you in the accuracy of your timing equipment?
Are you using the pulse timing method or luminosity probe? I suspect pulse, but always good to check. :)
What RPM did you time it at? Recommended RPM for the pulse method is 2000 RPM.
How good/consistent are your injectors? Do they all pop at the same pressure? Injectors that open at a lower pressure than the one being timed off of effectively have more advanced timing. You could try timing off of injector #4 instead of #1 and see if the timing is different. If it is, it could mean that the injectors are not opening at the same pressure.
In your case, it sounds like advancing the timing as much as you did was not a positive step. Try backing it off a degree.
chris142
SoCal
I bought the tool off of the snap on truck. I put a gizmo on the injector line then use my timing light. Notre sure what kind of style you would call that. My timing light is an older made in USA model. I believe it is accurate and it has a dial back knob on the back. I have no clue about the injectors but the pump was rebuilt before I bought the truck. I'll check it on number four and compare that to number one
In all honesty it sounds like you dialed in too much advance with your type of meter. With the lite flashing on the timing tab which location for the zero mark are you using. the zero mark is the short fat probe location at the timing tab on the dampner. Comparing the number 4 injecter is a good idea and defiantly use 2000 rpm. thats the only way we can reach the internal advance canceling method. What does the engine sound like when it starts up cold. Do you hear the engine get softer sounding when it comes down off fast idle and cold advance..
fordf350man
Rockwood MI
not trying to hijack the thread here but what would that mean if it did sound softer after high idle and cold advance? mine does that
mblaney
Ottawa/Ont/Canada
It indicates that you are close to the right timing. If you are too far advanced the engine will always be noisy. When timing is right the truck will wake up all the neighbours when cold but will very noticeably quieten down once it warms up and the cold advance turns off.
This also means that if you are retarded (engine, not the driver) then the engine will not have the noisy clatter when you start it cold.
fordf350man
Rockwood MI
thanks for the info, nice to know, i must say my engine is covered in grease and oil but it runs great,
chris142
SoCal
Now that the Sun is up I can really see the smoke. this aint cool I don't want to **** off any Prius drivers and get reported to the Carb. I'm going to bring it down a little bit
cpdenton
Truck needs paint.
Conway AR
I had the same problem with my truck. Went over to another members house who helped me set the timing to about 9.1 or so, best we could tell. He said it was Jumping around quite a bit. I had a lot of smoke and it was a lot louder. I think it must have been a sign that my pump is wearing out. Not consistently building pressure. I backed it off some, but not near as far as it was. Originally before timing, I was at about 4 btdc.
I still have some smoke that I don't like, but it is better backed off to about 8, and it runs a little better.
I have a new pump coming from Mel, and will set the timing to 8.5 like he call for.I'm hoping for less light throttle smoke.
Greg5OH
MI
timed mine to 9.8 as per icanfixalls spec. Stars much better (no cold advance or fast idle hooked up either), loud and very snappy throttle when cold. Calms down and throttle isnt super snappy once fully warm. I do have some smoke under accleration where previously at 6btdc i had zero smoke. Has more torque down low-doesnt feel "soft" when climbing small grades.
chris142
SoCal
I have not messed with it yet. I took it to lunch just now. It runs real good at low speeds. Revving it as I said earlier is lagging. But shifting @2500 or so its more powerful. Its definitely noisier though. Ill back it down after my boss leaves :)
FORDF250HDXLT
Maine & Oklahoma
not all of us make the claim that more advance means a better running engine.im @ 7 BTDC (pulse @ 2k rpm)
more advance for my engine just = more rattle,a loss of low end grunt (obviously doesn't tow as well) and more turbo lag.
banks sidewinder 2nd gen.
FMIC.
G codes.
maxed n/a spec ip.
peak (rare.very heavy loads + tow) 1k EGT (typical 600-800 egt range.)
0% smoke.
peak 8 psi boost.
rockbender
Bend, OR
I think that some people were suggesting a 1.5 ATDC lumi timing at one point, when spec is 5-7 ATDC. When my new pump was installed it was timed by ear. I have since timed it via a lumi probe (because its what I got!) and learned it was at 3 deg ATDC. I retarded the timing to about 7 ATDC and have been pretty happy with it. Some day I may try to advance back up to 6 ATDC or so, but the pump adjustment process in a van isn't that pleasant.
Don't let me confuse you with the lumi specs... just trying to give another example of someone content running a tad bit on the retarded side of what others are recommending.
Zaggnutt
PA
Laughed out loud at this... Thought I woke my kids up. Best laugh I had all day!
Caterpillar335
