Hypermax contact
kas83
Plover, WI
Which crossover are you referring to with the Hypermax setup? I may be reading wrong since I'm cooped up in the hospital, but I was under the impression that Hypermax uses separate up-pipes and the divided turbo mount to bring the pipes together.
Sent from my SCH-R760X using Tapatalk
vegas39
las vegas, nv
The pulse turbo uses seperate pipes, their regular setup runs both sides into one down below and then one up to the turbo
kas83
Plover, WI
Oh, gotcha. Completely missed that you had the regular setup in the first post.
pwillis
