Does anyone know if a late '99 model HPOP will work in place '94.5 HPOP if the IPR is switched out as well. I'm needing to replace my '94's HPOP so I'm trying to find out what's compatable.
i know that the early model pumps '94-95.5 had the anti-drain back component in the pump itself. Is that component a part of the HPOP resevoir housing on the later ones?
