8gitmusik1
1994_E350_7.3_IDI_N/A_E4OD
Hello DIESELBROTHERS!
What do you all think of putting petcocks on either side of 6.9/7.3 IDI blocks for easy, draining of coolant from engine blocks when needed? Is it a good idea/bad idea/hazard/dangerous?
Where can I find info/pics and pro's and cons on replacing coolant drain plugs on 6.9/7.3 IDI blocks? I am replacing radiator, all hoses, etc.
If it is a good idea, not to crazy a mod, and not too expensive then I want to do it once and have it on mine and done since it will be all apart anyway.
Anyone that has done this already...... what is the thread size for the coolant plug and are they the same or different for the driver and passenger side of the block?
Also, is it course or fine thread and anyone have written down the correct diameter of plug hole so I can get the correct petcocks before I begin.
Also, any suggestion of best brand of petcock to use? Is there a "KIT" available (hint (thewespaul)?
ANY BEST PRACTICES OR PROCEEDURES THAT WORK BEST?
Also, have seen people running clear hoses off petcocks and Im concerned about heat issues if I do that as well.
Please post ANY pics, step by step help,
Does anyone have any more info/ experience on this topic?
Sent from my SM-T567V using Tapatalk
