turbodiesel94
So in say a 50/50 mix would hyd. oil be alright?
Please do.
I have a customer wanting me to build him a centrifuge system, but I am finding too many people experiencing problems with the PA biodiesel parts, to buy from them.
Thanks.
Has any one here heard of oiltofuel.com ?
i was just curios how you were going with th pa bio centrifuge? and the wmo. I have been able to use higher ratios of wmo in hot weather than these guys suggest. do you find wmo after being run through the cent. seems to burn "cleaner?"
So...does the oil look clean when you pull it, like at least light could go through it? I ask because that seems to be the claim on the first page of that site.
From what I understand, you can not spin the oil fast enough with the current personal use centrifuge to get the suspended ash out of it.
SWS
I started collecting oil for this purpose - it seems people are just running the oil through progressively smaller filters and cutting it at the end (50/50 or 85/15 for example) and dumping it into one tank. One tank for start-up and shut-down and the other for the WMO mixture.
So using used diesel oil is not recommended? I work at a shop with 15+ Pete dumps, oil changes are constant. I could get a lot of fuel from them. Is there a need for warmed fuel if it is mixed 50% WMO 50% Diesel?
