Suddenly
After having my IP timed I’ve decided to turn it up a bit and see if there’s a noticeable difference in power or boost numbers.
when should I stop turning it up? I did 3 flats and took it for a test drive, I gained 1 max psi as far as I can tell. From 7 to 8 psi max.
From a stop I launched to 140km/h I saw max ~750 egt and 8 psi. The truck is intercooled, 4:10 gearing 150000km on the engine and I think the IP is original. Turbo rebuilt a few years ago, and the wastegate was unplug for the tests. It smokes like a chimney if I floor it and it drops a gear, but if I’m wot cruising there’s no smoke.
Should I keep turning it up until it smokes on wot then turn it back down a flat? My understanding is black smoke=not enough air, is that when I stop and turn it back? Do I need to tow my trailer around so it has a load for testing?
Thanks, Dan
Thanks, Dan
