How do I fix this fuel leak?
jayro88
Auburn IN
So I got my van running again. While doing this I noticed I was dripping diesel when it was left running. Digging into it I found I was leaking fuel from here. It is circled in yellow:
Has anyone else had an issue with fuel leaking from here and is so how did you fix it?
Thanks
That's the heater, there is an O ring in the filter head, it can be swapped out, look in the parts bin for part # It is listed.
On a truck a super simple fix..on van however looks daunting!
gandalf
Senior Member
Air Force
CA &/or Maine
It's a bit hard to tell what we're looking at. Most of us aren't too familiar with the van setup, and the ways it is similar or dissimilar to the truck.
Could you back out just a bit and give us another view showing a little more of the surrounding area so we can orient ourselves?
That is the sucky fuel heater o-ring. Its a simple repair too and the o-ring wil cost about $2.0 at International dealers. The part number is in the parts bin section too as posted above. Its really a not needed hester too. Many have removed it and used JB Weld to seal up the hole. A quality RTV can seal it too. Just allow it to setup before running the engine. You must remove the filter and the bracket to reach the underside of the filter to get at the heater. Its a simple plate and metal bare wire that heats up the fuel. We don't even know if this works or if its only on in certain low temps. The psd fuel fitler cans have this heater in the bottoms where it possibiliy can actually work. Ours is in the top. Heat rises so hows that working...:dunno
cpdenton
Truck needs paint.
Conway AR
If you decide to remove it, like I did, there is another way to seal the hole permenantly. Take it all apart. This involves taking it off the mount, removing the fuel filter, removing the large threaded nut that the filter screws on. Then the hearter will come out of the hole. this step has to be done to change the o-ring as well.
Buy a 1/2 in npt tap and a 1/2 in pipe plug. Tap the hole and plug it with the pipe plug and a little thread sealant.
Thinking about it now, I could also fit some adapters on that threaded hole for a fuel pressure gauge. Hmmmmm.
jayro88
Auburn IN
Thanks for the help. Thinking I will try replacing the o-ring. Ford want $160 for the heater element. I am thinking about just doing the tap/plug thing, but I am a little worried about the fuel getting cold and clogging the filter. We usually get some sustained single digit temps in the winter. Anyone have first hand experience with this?
This is another idea others have used with great sucess too. I see lots in this pic. The truck runs 134 freon. The filter head has the vacuum senser on it telling the driver the filter is plugged. Also the glow plug controller had buck off the cover that keeps stuff from grounding on the how wire on top of it.. Also I see a boost line so this is a turboed engine.... Anyone else see anything else...
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
I know, not the same engine, however, the Fuel Heater in the HFCM on my 6.0 has been disconnected for I believe 3 winters now. Not had an issue. In the later 6.0's and the replacement HFCM's there is no heater in them at all. So I don't think these really do a lot. The only time I personally know of anyone having issues with a filter freezing up was Trav on E-1.... but he later found out the truck stop he bought fuel at, had a little diesel in their water...........
cpdenton
Truck needs paint.
Conway AR
You are on it Gary, truck leaks a little 134 a at that adapter fitting....
I found my GPC cover laying on the passenger side exhaust manifold over the weekend. The little clip was broken off. I think I have another laying around here somewhere.
I am running a banks sidewinder.
My feeling on the heater is this: I think it would be much more likely to gel in the tank and lines under the van/truck than right on top of the engine. That would be the part of the fuel system that is most insulated from the elements.
Whay are you talking to the Ford dealer about buying a complete new heater.. Thats not needed. The international dealer sells the o-ring for $2.50 each to fix this leak. Don't let some clerk sell you what you wont ever need. My oem heater was broken and leaking for years. Then I opened it up. Replace the o-ring. Soldiered the heater wire back to working order but still say they are never needed. Nobody has ever said there is a must have or die item..
I had my old '85 6.9 running at -4. It acted a little funny for the first mile or so, but straightened out and ran fine. The lady that runs the station where I bought my fuel at the time said that it wasn't blended, but who knows? I don't remember for sure, but I don't think the fuel heater was even hooked up.
yARIC008
Drives really slow
Orlando, FL
If you look on youtube there is a video showing how to replace this o-ring. I replaced mine a couple months ago. There are two different styles, I think one style uses one o-ring and the newer style uses two o-rings of different sizes. I wasn't sure which one I had so i bought big bags of all the various sizes. If you want, PM me your address and I'll mail you some.
As for the daunting comment on the van. Not really, just remove the air filter, loosen and remove fuel lines then unbolt filter assembly and pull out of van from passenger compartment with dog house removed. Have to contort your body some but not that bad.
jayro88
Auburn IN
Yeah, its not too bad. I had the assembly loosened and off to the side when I did my IP for more room. I will shoot you a PM with my address. Thanks.
Curiosity on price and I had read a number of people who replaced the o-ring and then it started leaking again a week/month down the road. It doesn't look like a very difficult job, but I still don't want to have to do it more than once if I can help it. If the price wasn't too bad I would consider the new unit.....but $160 IS to bad.
Remove the heater... Plug the hole and run a fuel conditioner in the cold winters if you think its going to gell up on you. The cost of $160.00 in conditioner will get you thru plenty of winters. This forum is all over the world in some really cold places. I do not recall of any of those members saying they rely on this fuel heater. Really now.. Do any of us even know if ours are working. Really not an easy way to make sure they work or not. Other than removing the wire and wait and see. What I personally would do is remove the wire. Run a anti gell fuel contitioner and theres plenty of great information to that here. then run the rig thru the winter. See if anything changes. Once again do you even know if your heater works. So why replace it for $160.00. Buy conditioner and plug the hole. Any van in a wrecking yard will have this filter mount so you can buy one as a spare for the ... Just in case I gave you bum information on this. These engines have several items that have never been proven as necessary. Like the cab heater bypass line on the return that branches off to the bottom of the radiater. Its factory to hurry the trans fluid warmup.. Not really needed. There is also an orfice in the cab heater head nipple fitting...:dunnocookoo:D Why do we need that.. BTW Ford no longer sells that. I "found this" when I rebuilt my engine. So I went to a dealer and wanted it.. Well they did a nationwide search. Only one was found about 20 miles from me.. I bought it. Do we need it Nope. There are several more items too like this.
jayro88
Auburn IN
From all the info I am thinking that it is not needed. I usually run the winter Diesel Kleen in the cold months anyway.
Should have seen the guy at the Ford dealership freak out when I mentioned deleting it........said it would cause an issue anywhere except places like Arizona. I had a feeling he didn't know what he was talking about and probably had zero actual experience with the IDI.
But then he also gave me a crazy look and I had to repeat myself when I asked for a price on an '88. Kind of like "Why the heck would you have an '88 and actually care enough about it to be looking for parts?".
waltynguyen
Staff online
