How do i find out if it's a cab and chassis model?
warhog
TN
I'm looking at a truck for parts (mainly the rear axle), which from what i gather will differ between pickup and cabchassis model. I have the trucks vin number, would that help?
2fdjf37g3dca41398 Where would i look it up?
edit nvm. cab chasis. :( I don't think i'll ever find a rear for my ol girl.
cpdenton
Truck needs paint.
Conway AR
What rear end gears are you looking for? I know where there are two f-350 trucks, one is an 87 or 88, the other is a 92. The 92 is an idi.
Both are located in central AR. At a salvage yard. About 250 I think.
warhog
TN
sterling 10.25 i believe, preferably 4.10 but really anything at this point. AR is a bit of a haul, but i'll keep it in mind. Heck, if there was a website i could ordera rebuilt one off, i'd even be tempted to go that route.
This parts truck seems real clean though, not a diesel but for $500 sure would be a deal to just get running and drive.
cpdenton
Truck needs paint.
Conway AR
This 92 model is just like my drw truck. It is a sterling 10.25 and should be a 4.10. It is at a u-pullit, so there would be some work involved....
warhog
TN
There is one at a upull it a little ways from me, but I haven't had any time what so ever to head over there and see what might be involved with getting it to a truck to bring it home.
Shadetreemechanic
Monteagle, TN
That red and white one in tullahoma was still there last weekend. If you show up on Saturday they can go out there with hydraulics and make sure it is safe to pull.
I am having front axle issues. I pulled parts last weekend off the 4x4 air force truck they have down there.
I also have a 3.73 dually axle off a cab and chassis here at my place. If you want to make it work its less than a mile from where your truck sits. We could probably make a deal on it.
warhog
TN
Thanks man, I wouldn't even know the first thing about rigging up the cc model rear. How would I go about getting the rear from the tullahoma one? Do they have carts or something I can roll it to the parking lot with? And do they allow cordless sawzalls? Figure that would be the quickest way to get it out...
Shadetreemechanic
Monteagle, TN
They have carts and a rolling lift for pulling motors etc. Cordless tools only so sawzall is it, but they will let you plug in your charger.
they are charging $100 for the rear end with drums.
FORDF250HDXLT
Maine & Oklahoma
it wouldn't do you any good.you need the pickup dually axle if yours is a pickup.
you could bolt a cc axle under there,but you'd have to move the spring hangers outward where they belong to bolt to the pickup frame.then you'd end up with a srw pickup axle doing that though,so don't bother!:rotflmao
a sterling drw pickup axle sporting 4.10's is easy as pie to score.it's just going to cost you,but you could find one in no time.you should try the 3.55 drw axle hunt some time.now that's a real good time lol.
http://car-part.com/
warhog
TN
Thanks shadetree, hopefully i can head up there this weekend and scout. If you're in the market for a truck....$673 for a 83 f350 in lebanon. looks to be in great shape. Gasser, but still.
250hd - I check that site almost weekly. Only one within 100 miles on there. :( My hub seized on the drivers side enough that nothing short of cutting it is going to get it off. Happened going down the interstate, so you can imagine how my new tires held up....Going to have one dismounted and spun 180* and that should help it out over time. Wish it didn't have that darn dowel pin on the rim.
warhog
TN
home depot does sell battery powered angle grinders..hmmm
Shadetreemechanic
Monteagle, TN
I pulled the FSV off of that truck in Tullahoma about a month ago. It is really rust free underneath. You might be able to get away with sockets and breaker bar.
I pulled a front axle mount off a 4x4 in the next row last weekend. That was a muddy greasy mess, but the bolts all came loose with pbblaster.
I don't need any more trucks at the moment.........which gets me to thinking, forget that axle in Tullahoma, let me sell you my superduty parts truck, then you can have disc brakes in the rear with 5.36 gears. With those gears the truck will never reach interstate speeds so you dont have to worry about your hub seizing on the interstate.
warhog
TN
hahahaha, it barely gets to 65 as it is without howling (4spd :( ) I'm not sure if youre serious, but do I have any other options that don't require a master welder to get it to carry the truck?
bneumann22
