Sycostang67
Scooty Puff Junior
While going through my engine compartment, I noticed 3 leaking caps on the injectors. Looks like I'll be purchasing a return line kit, as they are all gray which means original with 118k miles. It looks like a fairly simple and straightforward process, remove injector lines, swap caps, hoses and o-rings. Going through posts and looking through the kit I see I will be relocating the crossover line to the back of the motor. I will also be changing the fuel filter while everything is apart. Is there anything I should be aware of before diving into this project. This is my first diesel, so assume I know nothing.
Actually any grease will work great. Use a dentel pick to remove the old o-rings and keep things really clean. Install the first o ring on the top groove. Then roll the second one over that one till it seats in the bottom groove. Make up the caps and lines using the old set for a size and press them on till you hear and feel a click. Job done. Loosen the injector line clamps but don't remove the nut and bolt. They are really tuff to reinstal. Having the lines loose will make it easier to thread the lines back on the injectors. Don't cross thread them. Its really easy to do too. I like to hand thread the nuts all the way down the injector. That way you know they are not cross threaded. You really don't need to bend the hard lines much at all. The caps will come up and off the injectors easy. Post back if you get stuck or have questions. Plenty of help here all the time...
