Holy F&@$ there’s nothing holding my transfer case on!!!
blackdog76
ca
My trans suddenly started slipping and I’ve been having a torque converter drain back issue, so I decided to check the fluid levels. Trans looked fine and when I went to check the transfer case I was horrified to find that my transfer case was not connected. I could physically rotate it by hand. Only 2 studs remained and were just literally hanging by a thread. My question is did this possibly damage the transmission by all that weight on the rear shaft?
Clb
Another old truck
nannyfornia
Of course it saw something less than optimal.
Put it back together with some locktite to keep it bolted and see what happes, look for leaks and shrapnel in the fluids.
If the slushbox is cavitating, you already have issues.
If it goes away you might have won.
blackdog76
ca
I have new studs and nuts on order. I guess after 450K things are going to come loose.
blackdog76
ca
I took the case off today. Three studs broken off in the housing.
FaithK0585
