Hey Whitmore
jponder
Atlanta & Tangipahoa Parish
How are those 285's holding up. Those puppies are STOUT!!!! I am rolling down the road at 12K lbs and the tires are at 110 psi and they will shake your teeth out your head. I been thinking of putting a coulple of 55 gallon drums with water in the camper to try and get my weight up around 14,000 lbs to smooth them monster tires out.
I guess I guess I could just lower the pressure, but thats is the sissiefied way out, NAW weight is what i need!!!!!! :D :D
Whit
lost in Why-homing
110 psi.......no wonder yer teeth are rattlin, I took my psi down to 85 and it is alot better, I still think airbags on the back would be a great setup with these stiff tires though, if it werent fer my homemade traction bars I would consider it.........hindsite 20/20......also I notice a diff in the ride when my in-bed tank is full too.
Cheers, Kevin
jponder
Cheers, Kevin
You are running the yokahama right? The spec sheet on that tire only goes down to 95 psi. Dont know why. I have the airbags but in hindsight. I think the 265's with no 2 inch leveling kits and the standard camper package springs with only ranchos 9000 would be the simplest setup and work well.
Of Course then I wouldn't get to watch people stare at my monster tires at the red lights :)
Whit
lost in Why-homing
Yes they are Yokohamas TY303's I would really like to see some pics of your airbag setup when ya get time, I never checked pressure spec on my tires, I just took em down to 85 psi and find the tire wear to be fine and when towing my 19k backhoe on a 7k trailer they still look very stable, my tires are rated for 6400 lbs each...............heck with no load on I bet I could run with 0psi and not notice, load rating is "H" on these monsters :D
pwillis
