adamsanders
So some of you may recognize me from a recent thread about a new IP. To summarize, I recently bought and installed a new Mini Moose. The injectors on the truck may be original, they have grey paint, are labeled stanadyne, and have a "D" on them. Anyways, I have a problem where the truck runs really rough in spurts. It misses hard, starts knocking and rattling like crazy but then will usually level out and start idling ok again. This only happens after I actually drive the truck. I can't replicate it by just idling. I had settled on bad injectors but just for kicks I decided to check the Schrader valve while the truck was running. To my surprise NOTHING came out. No air either. I kept holding the valve open and eventually (10-20 seconds) the truck started stumbling bad and died. Took a second to get it fired back. The lift pump is within a month or two old and puts out fuel while cranking. The truck fires right up cold every time. What could this mean?
Here's videos of that sequence I described and the rough stumbling I have been experiencing. The second video is the missing/knocking after I have held that valve down for a while.
