Finally got this engine all put back together as of the end of May, seemed like everything was ok, (outside of needing a new IP) now I'm getting mega blow by. (almost the same from before the rebuild)
After I was back on the road, did the normal,"drive it hard to break in routine" what some here have said a rebuild motor should have.
I just changed oil for the 3rd time since start up.
Have about 2000-2500 miles on motor.
Switched the CDR valve, but with the amount of pressure coming from crankcase, don't think the CDR is to blame.
Over this last weekend,drained the oil, pulled all the GP's and pumped in about 2 qts, divided out between all cylinders, of diesel fuel. Every morning and evening turning the engine by hand, forward and backwards.
Most of the fuel ended up in the drain pan after the fact, I measured it out from the drain pan.
Monday night with Gp's all out spun the engine with starter, to make sure it was clear.
This took place from Friday night-fill up to Monday night -restart.---no difference on blow by
When I first got it all together and driving had very little if no BB.
I've narrowed it down to a few things I think it could be.
About a month ago some friends of ours said they use a deep fat fryer and have some oil to get rid of, I said no problem I could use that.
First possible cause??
This probably was no more then a gallon. So I filtered it, took about half of that and run it with a tankful of regular diesel.(Don't think this would be enough to cause stuck rings on a cylinder....but maybe??)
Second possible cause??
The other 2 quarts I put in a batch of wmo that I run through my CF, filters and into my heated tank, have only burned about 10 gallons of that wmo tankful.(Another possible problem area...???)
If I have some stuck rings, is a auto RX time, or some other item to clean things up??
If my rings have not seated, is there a way to get them to seat???
My next step is doing a compression check on the engine to find some problem areas..
So let me know what you think, questions, comments or general direction I can go. Thanks
