heating the oil in the truck
subway
be nice to the admin :D
York PA
i want to set up a system in my truck i have already swung the greascar switching valves and a 40 plate exchanger. but what i want to know is how do you run the coollent lines? i want to to a HIH setup back to the tank. so where do i split the heater core hoses? i want to be able to run as much of the year as possible (York, PA). should the flow be throught the heater core first then to the filter then plate exchanger and back to the tanks? or does the system run in parallel with the heater core.:dunno
can i loop the return right back to the filter?
thanks
Big Bear
