Headlight Upgrade
FordGuy100
Silverton, OR
So I decided to throw a new bulb into my truck to see what it would do. I have the LMC truck headlight relay'ed wiring I need to put in. I only wanted to spend a couple minutes doing this as I had to head to work. New bulbs are on the left, old ones on the right.
Low beams:
High beams:
ocnorb
IDIT
Wasatch Front
So is it a special bulb or just a stock replacement??
Also just to be clear- you have not installed the relay on the headlights? Its kind of hard to tell what you meant.
FordGuy100
Silverton, OR
I have not installed the headlight relay yet, but I do have it on hand. Bulbs are Hella 90/130w...offroad use only. I think I might actually go down in wattage, but time will tell. Truck was off in the picture (so they should be getting another volt when truck is running)
gatorman21218
Ashland VA
the lmc relay made a huge difference for me. i mean I was driving around with the brights on and noone flashed their lights at me. and it takes all of 5 mins to install
