Head studs in and heads stayed on
That sounds scary as hell. :eek:
LOL
I had to replace one bolt ONCE, at the end of a headgasket change out job, because the washer broke as I was torqing it. I'll never forget the sounds the head made as relieved all the tension there to replace the bolt and retorque it. Sounded like ceramic bricks sliding against each other. :eek:
david85
Campbell River, B.C.
LOL
You must have had nightmares for weeks after that. That sounds scary as hell.
91f2504x4
KY
There were lots of guys who had 6.0L trucks that done this exact procedure, just as a precautionary measure, and as far as I know none of them had any head gasket issues afterwards. There was such a big scare about 6.0L headgasket problems for a while, lots of guys swapped bolts out for studs the same way that the OP did and they had good luck with theirs. It was more of a piece of mind for them than anything.
RLDSL
Diesel fuel abuser
Arkansas
I don't see why it would be a problem. It is really not much different than a proper retorque procedure where after X amount of miles you first release the tension on the head bolt then re torque to spec. On a re torque you must release the tension on the bolt first or you will get a false reading on the torque wrench while breaking the tension loose on the bolt. You only get an accurate reading while the bolt is in motion, so for that I don't see a whole lot of difference. Only difference I do see is in the tightening procedure on the stud as in the 5 steps ditty not being followed. I'd be inclined to go back in there and go after those critters another 4 times to make sure the final clamping force is where it was intended to be, and I'd do it in sequence one step at a time to avoid cracking.
crash86
texas
Ive hit 19 cant push anymore out of her but its crazy that i can only get 12 or 13 without the propane but no problems so far knock on wood
Knuckledragger
Payson, AZ
Sometimes the shortcuts work out just fine. Good for you!
I couldn't figure out how to get the head bolts off without pulling the engine (leading to an entire rebuild), but never thought about taking off the A/C condenser fairing. Good idea.
dyoung14
Is getting worn out
spencer,tn
wow, you need to post some videos of that thing! i bet 19psi is fun!:sly
91f2504x4
KY
I wouldn't mind seeing a video either, in my truck it doesn't seem like it makes any more power past 15 psi, maybe I am just worried about popping a gasket but when I am climbing a hill I can push upwards of 15psi, roughly ~18psi but it seems to pull the hill just the same if I let off the throttle a little and let the boost fall below 15psi, it makes me feel a little better too.
dyoung14
Is getting worn out
spencer,tn
with head studs i would feel safe pushing 18-20 into a 7.3, but i guess thats just me:dunno
91f2504x4
KY
I may install my intercooler soon, and see if it feels like it makes anymore power beyond 15psi after that. Right now it just doesn't feel like it pulls any harder above 15psi though, I just worry I am putting extra stress on the engine for no reason.
dyoung14
Is getting worn out
spencer,tn
yea i understand what you mean there, i bet when you put that intercooler in there it will be a hole different animal
pwillis
