Having problems with 7.3L IDI oil leaks..I need HELP please.
williampryor79
Alum Bank, PA
I have a 7.3 that was just put back in my truck after having it "so called" resealed. All new gaskets for the motor, but only about a 1/4 of them were used. Oil was leaking out the remain seal. We put a new one in to find out that the crank shaft had a repair sleeve on it. We pulled the sleeve off and found the crank end was in almost new shape. Put a new seal on it, drove maybe 20 miles with no leaks. I let the motor sit over night went out and started it, let it warm up then pulled my flat bed trailer (1400 pounds) maybe 8 miles. Walked in the gas station for 5 mins and came out to 1/2 quart of oil on the ground and the back of the motor soaked. But now in my drive way no oil is leaking...I am stumped to the point of almost hauling it off....I need HELP please...
My question is are you certain it's the rear main or could it be pan..
Did you use a pan gasket or just RTV?
What about valve cover gaskets could they be leaking on back side????
Steam or pressure wash engine off really good, add some florescent UV dye for oil to the oil then as soon as a leak occurs check it with UV light and trace it...;Sweet
Sounds like you had someone else reseal the engine, replaceing the rear main seal with a wear ring is the standard procedure, it comes as a set. Are you sure that the leak was/is motor oil? A fuel leak will run down the back of the engine and wash any oil/crud there, the intake manifold gasket is fastened at the rear with a plug that has a hole in it for draining. If no oil/fuel is leaking, why are you concerned now?
Many times a fuel leak on top of the engine will look like an oil leak. What happens is fuel can leak from several places at or near the injecters. It then runs under the intake manifold and out the rear drain in the pan under the manifold. Its only able to run down the passenger side of the rear edge of the engine. Usually its running of the starter. Now the fuel washes off some oil and dirt so it looks like engine oil on the ground but its not. As was asked, did you use a oil pan gasket. If so thats a mistake. They are not needed and the factory used rtv only to seal the oil pan. Thats worked great for many years so why change it now. Hope we can help you find the leak and fix it for you. You seem to be a new member here so welcome to the forum.
williampryor79
Alum Bank, PA
I did have someone else do the reseal on the motor and when the motor came back to me it was half done and the other half in bags. I gave him $300 in gaskets and he used 2. He RTVed the rest of the motor. The oil pan is RTVed. So from what I am seeing a wear sleeve should be used when you change the rear main? If so I will have to get a new one as the old one was taken off and the crank was in like new shape so we put a standard seal on it. There was a fuel leak at the injection pump that was fixed. From what I seen this morning it was oil, NEW oil running down the passenger side of the block. Just about 45 mins ago I went out and was working on the truck and there is hardly any oil leaking if any..Now I am stumped.
williampryor79
Alum Bank, PA
RTV was used on the pan, valve covers have new gaskets in it. I know they are not leaking as I have looked at them 100 times since we put the motor in and got it running. I am stumped
williampryor79
Alum Bank, PA
Got an up date on the oil leaks...I think I got them stopped...The oil breather line to the turbo what pinched off and causing to much pressure..We will see how it goes..
What oil breather line to the turbo?? We only have an oil feed and return drain to and from the turbo. How can a drain line get pinched and create pressure...:dunno Hope you have it fixed.:thumbsup:
cpdenton
Truck needs paint.
Conway AR
Perhaps he means the CDR? Building too much crankcase pressure causing seals to puke out oil.
Perhaps, just perhaps they didn't replace the intake manifold gasket. He stated they only used 2 gaskets, but didn't say what they were. Head Gaskets? Since it's an 88 IDI, a turbo was added, the older style intake gasket underside baffle will not drain the turbo oil fast enough if that's the place it was returned, holes have to be punched in the baffle to rectifiy that.
That tells me he was running the engine, now it sets idle, so the oil stopped running.
bleachasaurus
