InnovativeAV
I had a local shop put new glow plugs in my 2003 7.3 power stroke. My up pipes were also leaking so they replaced those with the new ones that I guess the flanges bolt together. They had to remove the turbo to do the up pipes and for some reason it doesn’t feel like it’s making boost they think that my wastegate is sticking which I believe it has stuck before I’ve had it open up and not shut until I slow down. They are suggesting to Put a plate I believe or pedestal where the wastegate goes and get rid of the wastegate so it’s basically like an open turbo does this seem like this would be feasible. I have a TS6 chip. Stock injectors. Stock turbo. When they pulled the turbo they said that it barely had any up-and-down play but I had zero in and out play so they said that the turbo is fine.
Any ideas. I could hear the turbo a little bit but not like I used to and it just didn’t seem like it had anything plus it was blowing a lot of Blacksmoke
