well you can mount as linked but then the turbo is still right on top of the motor and with the bigger hx35 its more of a pain
im doing this gm style on a side mount with a crossover pipe
heres a link
http://www.oilburners.net/forums/showthread.php?t=47648&highlight=turbo+build
i need to weld up the manifold get oil lines made up and an airfilter then its done
also this way the turbo is easier to access for me to pull it off swap housings and throw back on
now im stroked to 7.7 so im running a 21cm housing to start then if need be ill put an 18 cm on but for a stock motor a 12cm will work well
also i plan to do water or propane ram air for this setup and some other mods down the road
i plan to be in the 300 hp range once the turbo is done with the stroker kit
you can expect high 200s with a stock motor
then im going to build to 500 which will mean ic air grid heater higher boost ill be using the stock 17psi wg till i get time for studs then its up to 30 or when i feel its bad and possibly a compound setup
