FordGuy100
Is welding cast aluminum easier than say, cast iron? Just out of curiosity...
....I can take the transmission out without touching the t-case or the front shaft....The only bad part about a 205 is shifting them into gear - they can be a ***** to get into 4H.
i guess you guys are missing the big picture. take the bw1354 and remove the frt output shaft and chain. cut the case (where the frt output was) as close to the gear case as possible without cutting to much on each case half. weld alum plate where you removed the frt output shaft. put halves back together and seal it up. install to transmission and there you have another low range. also it lets you keep your 4x4 transmission and run a divorced mount transfer case.
i am in the process of doing this setup on my trk. but im using a 203 mounted to my zf5, with a divorced mount 205. also i will have three shifters just for my transfer cases.
