But where would I put my spare tire? My biggest conundrum.You can change that, you know.
That's a ton of wear on those brushes for just a year. Maybe bad Chinesium brushes? The copper on the commutator looks fine from this angle.Any ideas? Clean up the carbon and send it?
I'd definitely run new brushes, a light sanding of the copper and send it. They are supposed to be good units... check wire continuity while wiggling them to check for bad connections too.That’s actually a really good idea to have a backup. Maybe I’ll try to clean this one up and replace the brushes and use it as a backup.
Try reducing the bypass at the top of the fuel filter. That pump has lots of cap - most of the fuel is vented back to the tank.I am running a Walbro FRB-13. Doesn’t quite flow enough, with maxed out Moose Junior pump I can outrun the Walbro pump and starve for fuel.
R&D makes one heck of a kit, regulated return and everything, I plan on getting one when they are in stock again.
I’ve already deleted the line between the filter and return.Try reducing the bypass at the top of the fuel filter. That pump has lots of cap - most of the fuel is vented back to the tank.
You can test this by pinching the return hose (at the filter) and the walbro will slow down almost to a stop.
These pumps are too critical and an easy failure point. Fortunately it didn’t leave me stranded, it stopped working when it was in my driveway.
