Good compression test results
Kevin 007
Full-floater
Nelson BC Canada
Had all the glow plugs out the other day to test em all prior to winter. 3 year old Berus, cold start them everyday. They were all perfect. Did a compression check while I had them out. 440-451 across the board. I was impressed;Sweet. That was with a cold engine.
It would be nice to know the miles on the engine but those are fine results no matter the miles. My engine described below has 530 lbs cranking compression. I have not seen any higher than that but there might be. Just have not seen it posted here. Doing a cold test is about the same as a hot test. Remember we have oil squirting up under the pistons so its going to be wetting the rings and the cylinders. This is simalar to what is done in a gasser when you test dry. Then squirt oil down the spark plug holes to wet the rings. If that compression comes up you've got shot rings. If it stays down you've got valve issues like a possible burned exhaust valve. Very seldom does an intake valve burn. They always have cold air rushing past them.
Kevin 007
Full-floater
Nelson BC Canada
Sorry, its the truck in my sig. 215,000km. I believe I don't have oil jets as its an early block. Don't remember the exact serial number but I did check it once.
Wicked97
Nebraska
The oil squirters shouldn't affect your readings since they aren't soaking the top ring.
Kevin 007
Full-floater
Nelson BC Canada
what kit did you use to check comp?
Don't know the brand, no name on the box. It covers GM 4.3/5.7/6.2 Ford 6.9/7.3 VW 1.6/1.9 Mercedes OE series, Cummins 5.9.
I have owned all of the above at some point and probably tested most of them, all through the glow plug ports aside from the Cummins of course.. There are injector bore fittings also for certain applications. Not sure what it all fits in that regard.
I do remember it costing somewhere in the ball park of $150
The oil does affect the top ring because its wetting the cylinders. All 6.9 or 7.3 engines have oil squirters cooling all pistons. If you didn't have them the engine will melt down quickly. Its surprising how much heat is pulled away from the pistons by the oil squirters bathing them in oil all the time. Your compression results are still very good and equal across the board..
Wicked97
Nebraska
Your oil control rings and crosshatch determine what oil is on the cylinder wall regardless of how much is splashed or sprayed on the piston.
The same amount of oil gets to the top ring be it a 302 or 7.3.
When you wet test a motor your looking to plug the ring land and the cylinder with more than just a light film.
So no piston cooling does not lube the top ring.
Those numbers are very good and at least you got to test 8 cylinders LOL I had one that was 0 comp LOL
That's a whole nother story mind you!
Kevin 007
Full-floater
Nelson BC Canada
That was not a very good story to read.... Well, I guess its better for it to happen now, then in the dead of winter when its tougher to work on things due to the cold. Thats the way I always look at things, if a guy doesn't have a well heated shop......
Sgtbyersfw
