Gear Vendors Install on 7.3 C6 with 4.10s
OR_Coast_IDI
OR Coast
My wife drives a Tahoe, and my dads truck (god rest his soul) is a 355000 mile 99 Z71 Silverado rustbucket. I just cant get rid of it.
How'd it all turn out for you KY? Eagerly been awaiting a followup!
I picked up a used GV and BW1356 a while back - haven't gotten around to opening them up up for inspection/rebuild or installing yet. My rig has a c6 w/ one of Quigley's Tailshafts, mated to a BW1346.
Fingers are crossed that the BW1356 matches up OK and nothing needs too much attention before install.
Curious to hear about your experiences.
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
I have on on an 86 6.9 2wd with 3.55’s I have the OD switch on the shifter. Did away with the auto shift since it always “thought” it should be in OD at a dumb time. Used a control box from Maximum Overdrive. Still has the minimum mph cut out feature to protect the clutch.
Ran a lot of secondary hill country roads with it. 2nd gear OD is awesome! No problems in 50k miles.
As for fluid I run Allison Transynd, the stuff used in the Allison’s in garbage trucks.
KYBricksandBulls
Somewheresville KY
Oh man! Sorry I disappeared!!! Ive had sooooo much going on. The forum got put way on the backburner. The GV unit has worked AMAZINGLY.
I have kept the control module and everything hooked up like it should be. I just keep it in manual mode and hit the foot switch when I need that OD gear. The control box kicks it out of OD below 15mph, which is handy. And the 4wd lockput and reverse lockout works great.
Big Bear
