Bumping this old thread looking for some feedback.
Took the truck on a 600 mile-ish trip last weekend with the most load she's seen so far (under my watch anyway). She had 2 sportbikes in the bed, two more on a trailer, and a bit of gear. All told, my guess is she was towing/hauling an additional 2000-2500lbs. To say she didn't notice it would be a bit of a lie, but there was no struggling, either.
Anyway, temps on flat lands were exactly as before. She ran 200-210 depending on the grade and (seemingly) the time of day/outside temp. Heck, she even dropped below 200 a couple of times. However, on some of the more prolonged grades, she crept up quite a bit. I occasionally saw 220s and even peaked at 230 once. In most those instances, the fan kicked in (first time I've heard it do that since I installed the Champion radiator) and cooled it back off QUICK. There wasn't a set temp that it kicked in at, really, but she always cooled right back down once over the hump. The OE gauge never got over the 'O' in NORMAL and the truck didn't give any other indication that it wasn't happy.
Talking with members both on here and 'that other forum', it seems people see a WIDE range of temps coming from the same location on the engine. One member on 'the other site' used GlowShift gauges and swears that he has never seen over 200 on his gauge even when towing some very appreciable loads over the Rockies, and he has the Champion rad as well.
Any thoughts? I'm half tempted to replace the t-stat (OE Motorcraft, of course), but I've already run into a comedy of errors trying to be pro-active with work on this truck, so I'm more trying to take a 'if it ain't broke don't fix it' approach.
Mike
