Lugnutz
Any of you local guys looking for a new project?
I have an Eaton Fuller FS-6406A 6 Speed Transmission I am looking to sell. Was going to use it, but I have decided to go a different direct with the transmission.
The transmission is still currently in the truck. There is 239k on the odometer and I can start the engine and run through the gears. It's in a 2001 Freightliner FL70 I am parting out. $2000.00
Parts are also available through heavy duty trans rebuilders to convert this transmission into an Overdrive unit. Thus, making it the FSO-6406A.
As a comparison:
G56 trans ratios
1st - 4.23
2nd - 2.53
3rd - 1.67
4th - 1.23
5th - 1.00
6th - 0.79
NV5600 trans ratios (It weighs 360 pounds)
1st - 5.63
2nd - 3.38
3rd - 2.04
4th - 1.39
5th - 1.00
6th - 0.73
Fuller FS-6406A trans ratios
(It also weighs 360 pounds) *But* Larger flywheel and clutch assembly will make it a bit heavier.
1st – 9.01
2nd – 5.27
3rd – 3.22
4th – 2.04
5th – 1.36
6th – 1.00
Fuller FSO-6406A trans ratios
1st - 7.06
2nd - 4.13
3rd - 2.52
4th - 1.59
5th - 1.00
6th - 0.78
As a comparison:
G56 trans ratios
1st - 4.23
2nd - 2.53
3rd - 1.67
4th - 1.23
5th - 1.00
6th - 0.79
1st - 5.63
2nd - 3.38
3rd - 2.04
4th - 1.39
5th - 1.00
6th - 0.73
1st – 9.01
2nd – 5.27
3rd – 3.22
4th – 2.04
5th – 1.36
6th – 1.00
1st - 7.06
2nd - 4.13
3rd - 2.52
4th - 1.59
5th - 1.00
6th - 0.78
