Fuel pump block off woes.
cpdenton
Truck needs paint.
Conway AR
I installed my carrier pump at the same time I installed my moose pump. I have tried and tried to get the block off plate to seal. I have tried rtv, I have tried aviation form-a-gasket. I have tried to get this thing to seal about 5 times and I am still getting blow-by blowing out of the same spot. I have used gaskets and just sealant. The cover is flat against the block and not up on the ridges cast around the area.
I am beginning to think my mr. Gasket block off plate might be flawed. What plate have you guys used and are there any tricks I should do?
Btw, I have let the sealant dry overnight every time I have attempted to seal it.
Can't recall what plate I installed. I just recall a member explained about the small machined ridge at the top. some plates are too tal and rest on that ridge so they leak. Grinding them down makes them fit. now if the plate is the same size as the oem gasket then there is no reason for a bad fit and leaks. Try this. Make a paper gasket from the old lift pump. fit that to the new plate and see if you need to rim it any. No reason why we can't simply buy some gasket material and a piece of 1/4 inch steel or aluminum and make our own plates. A belt sander. A drill press and a scroll saw or a jig saw to cut out the plate. These are tools most have in the shop anyway.
cpdenton
Truck needs paint.
Conway AR
I think the problem is this. My block off plate is actually smaller than the gasket...I think this does not allow enough space for the sealing surface against the block. My plate is well away from that machined lip, and the blowout keeps happening in the same place...
I have a roll of gasket material. Maybe I will just make myself a new plate out of some decent steel, and not chrome plated.
Just so you know Al, I have been making the surfaces "surgically clean" too.
cpdenton
Truck needs paint.
Conway AR
I have a big block Chevy plate, but I think mine is messed up. Sbc plate has 4 bolt holes.
Mine just seems cheaply made. I just can't make it seal up.
No gasket is needed on this plate. Think of our oil pan gasketles seal with RTV. If any location was going to leak that sure is the place I would bet my money on leaking. The oil pan surfaces were not designed for a gasket and RTV has worked far better than any cork or rubber gasket ever could. but why that particular gasket is included in some overhaul gasket sets is a fee we have to pay. So its pay for something we don't use or need. So why can't we simply use rtv on the block off plate too. So your telling us your plate is smaller than the gasket. Good idea now is to make up a plate the size of the gasket thats the oem type. Or cut one from gasket material. Test fit it before installation.
cpdenton
Truck needs paint.
Conway AR
Thanks for the replies. I tried with just RTV first, because my thinking was just like yours. Going to try something else now. Got on Amazon and ordered a machined billet block off plate. I am hoping it will have a more true fit than this other one I have.
Good thing is this is a second truck. So I can afford to let it sit for a few days while I wait on a new plate. I have another reason I can wait too. We had an ice storm two nights ago....hood is still frozen shut.
Best Idea yet..custom fit it..make a nice cardboard template, then 1/4 or better yet 3/8" plate. Maybe weld in a bung or two and have a nice location for a return line from a bypass oil filter or something like that..
I'd be lying if I didnt say that the line about surgically clean didn't make me burst out LOL and make Wife wonder *** as she's watching here breaking dawn pathetic vampire movie next to me. I guess I disturbed her movie...DILLIGAF breaking dawn moives.. but I digress..
Those chrome plates are sometimes not perfectly flat to start with and as you noticed likely not made super well.
If you want to go one last time at the seal, I'd suggest grind chrome off seal side, then bead of good ultra red or some other good RTV tighten it in place but not super tight, allow to set for 4-6 hours then do a final tighten that should in theory seal yer plate...but eh...what do I know.
If you tighten it down all the way and squeeze out all the silicone and just have plate to block...that sucks...you want some silicone left to make the gasket...then tighten it down a bit more once it's got a set....this IIRC was what I was shown/taught many years ago and makes good seals.
Hope you gitterdun anyway you do it.
Good luck
S-west
Ct
Made mine out of some copper plate I had lying around, didn't seal the first time around, just redid it, gasket and rtv, I haven't started it yet but I hope it seals haha
S-west
Ct
In my case I will never go back to the mechanical pump, filled my case with diesel after having 3 fail on me in a month, one cheapo from advanced lasted 2 months, then I replaced it with the slightly more expensive one which was faulty out of the bag, then a carter pumped diesel to my crankcase after a week or so. So far I have had no problems with my mr. Gasket electric pump
cpdenton
Truck needs paint.
Conway AR
If I reinstalled the pump, the arm would be cut off and the in and out lines blocked off. No way I am going back mechanical after installing the electric, but and least the mechanical pump kept oil in the block.
I ordered a nice new machined billet block off plate, hopefully it will seal better.
cpdenton
Truck needs paint.
Conway AR
Well, I got the ice off the hood and pulled the plate again. Sometimes, you just need to look a little closer.
Wonder why it wouldn't seal?
heartfire567
