Hello!
I know that it's a pretty common problem for fuel tank sending units on these trucks to not be working properly. So, it's been a bit of a pleasant surprise that, over the last 12+ years I've had the F-250, both senders have worked flawlessly. I was therefore surprised to find my fuel level gauge not responding when I drove the truck last week. The gauge is sitting at the lowest point the needle can travel to (i.e. the same spot where it sits when the key's out of the switch), and the gauge doesn't move when I switch tanks using the factory switchover valve. I checked the fuse and cycled the valve a few times with everything else off, and I heard it moving, so I think the valve is okay. Certainly, the truck's running just fine.
Given that the gauge won't respond with the valve in either position, and given the suddenness of it all, I'm having trouble believing that the senders failed...it seems to me that fuel level senders generally fail more gradually than this, and why would they both fail at the same time? I pulled the plastic cover off the gauge cluster and tried moving the needle by hand to make sure the needle wasn't physically stuck...it seems to be moving just fine.
So, what else can I check? I should note that none of the other electrical gauges in the cluster have ever worked; they've been disconnected in favor of mechanical gauges since before I inherited the truck...so, it's a possibility that the IVR failed, if this truck has one (I want to say it does, but it's been so long that I can't even remember if one exists, let alone where it's located). Alternately, what fuse operates the instrument cluster gauges? FWIW the gauge illumination works properly, and I couldn't find another fuse that might control anything in the cluster. I'm sure I'm missing something simple...if necessary, I can go back to switching tanks at a set mileage and refueling at another set mileage like I used to do with my old van, but I'd love to get the gauge working again if it's feasible.
Any thoughts would be appreciated...thank you in advance
