BryantMarwitz
Hello all, I should have posted last night but I was hoping to figure the issue out without asking. Just dropped my rebuilt engine in the truck and I have been working like crazy to get everything finished on it because school starts in a few days and I don't have a truck.
Anyways the just of the issues is. I have fuel at the IP pump plenty of it. The shut off solenoid to the IP pump works, I can hear it click when you turn the key to the run position. The metering valve is free, made sure of that last night. I've gotten the to back injectors wet with diesel, not a ton of it just a little bit. However, no matter how much we crank we don't get any fuel to the other injectors. So we continued troubleshooting. I checked the wiring and the wire going to the shutoff solenoid gets 12.5 volts with the key in the run position but when the key is in the starting position the wire that goes to the shutoff solenoid goes dead. I've traced the wires back to the relay on the fender but nothing seems ary. Is power supposed to continue to the shutoff solenoid while the key is in the start position?
I just can't seem to figure this one out any help would be much appreciated
