flareside_thun
Reviving The General Tao
If it's hard to start once it's been sitting for awhile, chances are the injectors are leaking and washing fuel down the cylinders.
DesertBen44 here also has a really good write up on installing a quality electric lift pump in the tech articles. It completely deletes the lift pump, and you use a small block chevy lift pump eliminator cover to cover the hole your now gone mechanical pump will leave, and in doing so you will completely eliminate the possibility of fuel getting into your crankcase from there (aside from IP seals). From what I think, I would consider doing that if you have the funding.
I am considering doing it to my truck in the future to see if it helps start better...
Heres the link:
http://www.oilburners.net/forums/sh...pump-with-a-Facet-Duralift-electric-fuel-pump
BTW how is that pump holding up? How many miles have you thrown on it?
once again i shoot myself in the foot. i put a hole in my fuel filter with a drill bit. trying to save time and rush something. lesson learned. I cant get a new one til tomorrow, so everything is sitting there, just cant start it to make sure it works. also just to make sure i did it right what wire to the fss do i hook to? i could not find a good picture of it. is it the one closer to the front of the truck or back?
