Front end gear questions
fields_mj
Brazil, Indiana
I've got a D50 with 3.55 gears right now and it's trashed. The mechanic has now located a couple of D60 axles that he can swap out for me, but they have 3.74 and 4.10 gears in them. He can't find a D60 with 3.55 gears.
I'm thinking that it would be less expensive to re-gear the D60 than to swith the gears in the rear end (again). So, my first question is will the ring and pinion gear out of my D50 fit the D60 without any problems, or will I need to buy a set specifically for a D60?
Second question is a little more personal taste. If I choose to spend more $$ and swap the rear gears instead, should I go with 4.10 or 3.73?
Originally I had 4.10s in the truck. I no longer have the original gears. I didn't care for the shift points going from 2nd to 3rd. Seemed like I was always shifting in the middle of a turn instead of being able to accelerate all the way through it. At that point the truck was mainly my daily driver back and forth to work, but also hauled 6 or 7 truck loads of firewood each year to heat the house. 3.55's worked fine for that. Now we bought a 26' travel trailer (5K dry wt) and we go camping about once a month or so (hopefully more in the future). I like the way the 3.55s drive going too and from work (95% of my driving), but they are a little tall for pulling the camper. They work, but something a little smaller would be better. When I retire the truck, I hope to still keep it and use it for firewood and hunting (more off road driving) and keep it's replacment in a little better condition. Smaller gears would probably work better then too. Replacing the front axle is going to set me back a lot more than I would like, so the question really becomes do I pay less now and stay with 3.55 gears or do I pay more now and (hopefully) be done with it. The idea of being done with it sounds good, but something is always braking so the $$ will probably be the deciding factor. Not to mention, it's almost deer seaon and I NEED my truck back ASAP.
So no can find 3:55 geared D60 ok..
NO NO D50 not compatible with D60 thus no can swap ring and pinions!
You have a few options now, regear rear to 3.73 or 4.10 or regear front to 3.55 like you have now.
How bout this, do the math and I calculate the the 4.10 is 14% taller than 3.55 so you can consider that you will take a hit on fuel mileage but make it up in towing capability.
3.73 is 5% taller than 3.55 so not much gain or loss.
IMHO 4.10 gear set, throw on some 255x85x16's later down the road and you have a taller gearing than 235's for better fuel mileage ...
Thus locate a nice 4.10 for rear and go for it. You will haul more comfortably and when done with truck as dd then around farm it's a nice easy ride, easy to take off under load etc.
D60 swap requirements...
D60
Springs
track bar and mounts
Pitman arm
driveshaft
ubolts
shocks
That should just about cover it completely!
Other than those I can't think of anything else needed ...OH ya:cheers: for mechanic when job done!
Those are just my opinions and others may differ.
Try if you can and get yerself a posi or locker for rear end if you don't already have one whilst at it!
MechDiesel
