1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Fresh rebuild and now it burns coolant
Discussion in '7.3L Powerstroke Diesels' started by Oledirtypearl86, Apr 26, 2019.
  1. Oledirtypearl86
    Oledirtypearl86 Full Access Member
    33
    876
    434
    Sep 17, 2018
    Whitehall MT
    So a guy I work with as a 98 F-250 . He just had a fresh rebuild on the 7.3 psd and now it's eating coolant like crazy the shop it's at has pressure tested the cooling system and it checked out do any of you have any other ideas what it could be
  2. 13fcolt
    13fcolt former professional
    44
    71
    Apr 9, 2009
    Arkansas
    If no external leaks are obvious it's not going to be fun. Has the pressure test been done on a hot engine?
    Only so many places for coolant to go, If it's not on the ground I'd be checking both fuel and oil just to be safe.
    Typically if any part of the cooling system leaks internally it will contaminate the coolant, being the lowest pressure, but there have been those rare cases that crop up.
  3. Oledirtypearl86
    33
    876
    434
    Sep 17, 2018
    Whitehall MT
    Funny you say that that's what they ended up doing now they are pulling he motor I guess that's what you get when you buy a nap long block
  4. 13fcolt
    44
    71
    Apr 9, 2009
    Arkansas
    dang that's rough. Has the cause of coolant loss been found?
  5. Oledirtypearl86
    33
    876
    434
    Sep 17, 2018
    Whitehall MT
    Not that I know
  6. IDIoit
    IDIoit MachinistFabricator Supporting Member
    12,235
    1,713
    I had a fresh set of heads where the gawd daymned machine shop use a fricken socket extension to install the injector cups, and didn't use any sealant.
    leaked like a biatch
    check this first
Share This Page
