1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Found some factory discontinued parts
Discussion in '6.9L IH & 7.3L IDI Diesels' started by faaiish, Jul 12, 2019 at 11:53 PM.
  1. faaiish
    faaiish Registered User
    23
    6
    Oct 3, 2018
    I pulled my motor out two days ago to refresh my gaskets and found one of my motor mounts was deteriorating pretty badly. I had a P/S leak from a bad o-ring when I put in my red head steering box and evidently the fluid ate it up pretty good. Long story short I was looking for a good set of motor mounts for my 7.3 idi. Searching on this forum and others there was no really good after market options available and my local dealer said the motor mounts were no longer available. I called a dealer that was a little farther out because they had the factory water pump in stock and they told me they would check their data base at a company who only deals with discontinued ford parts. They had the originals in stock (they were $75.00 a piece with shipping). Just wanted to give those in search of the factory parts a possible option. Ask you local Ford dealer about this and hopefully you will be able to find that part you need. I will post the name of the parts service when I pick up the parts should be mid next week.
    Exhumis, Cubey and DaveBen like this.
  2. Garbage_Mechan
    Garbage_Mechan Garbage Mechanic
    511
    149
    Jun 9, 2008
    Central Cal Foothills
    I was able to find a set on eBay after keeping the search open for a while. Patience is your friend. Just set a search for the Ford part #s. I found a set of cab mounts this way too, one by one. Had to have faith they would a show up and they did. Still looking for a trans mount for the 96 and a few other tidbits.
    Ilovelamp likes this.
  3. chris142
    chris142 Full Access Member
    2,645
    184
    Apr 15, 2012
    SoCal
    My local ford dealer wont even talk to you if your truck is over 10 years old.
    Ilovelamp and Cubey like this.
  4. Cubey
    Cubey Full Access Member
    964
    156
    Oct 18, 2017
    USA
    A certain Ford dealer in a city is crap for customer service in the parts/service department. They just eyeballed an E150 I had with the hood up and said I needed a new engine for a coolant leak in a metal line. I took it elsewhere and had it fixed for about $300.
    For the same E150's recall, they said they didn't have the parts and didn't know when they'd get them. They had zero interest in helping from their tone. I called one 20 miles away in a smaller city and they were able to do the work the next day.
    The first dealer I mentioned wanted $125+programming (10 years ago) for a transponder key for a 2003 Taurus. The second dealer charged $50 including program for a genuine Ford key. I had them cut a door only key for $5 more.
    I had WAY worse service from a GM dealer for Takata airbag recall work on a Pontiac Vibe than I did for routine coolant flushing at a Toyota dealer, being a Corolla engine. I couldn't get a Toyota dealer to do the recall work since it was badged as GM, not Toyota, or I would have.
  5. Jason1377
    Jason1377 Supporting Member Supporting Member
    729
    245
    Dec 12, 2017
    Arkansas
    Local Ford dealers around me suck they don't even want to qoute me for a set of tires from my 93 or even a old farm truck I have access to that gets used for hauling hay cattle n farm equipment, just a shame but a locker they tried to talk me into a new pos rig with so many useless electrical crap
  6. tbrumm
    tbrumm Full Access Member
    1,213
    179
    Mar 24, 2012
    Richland Center, WI
  7. Thewespaul
    Thewespaul Supporting Vendor Supporting Member
    7,164
    5,169
    Jul 27, 2015
    Bulverde, Texas
    Energy suspension makes poly bushings available for everything in our trucks, they are stronger and last much longer than the oem units.
  8. Cubey
    964
    156
    Oct 18, 2017
    USA
    Cool. They have the sway bar ones for my RV. What's the difference between the red and black ones, besides the color and price? They must an awful lot of different ones too, 4 different kinds it seems. Maybe the Crapazon catalog isn't filtering properly...
    https://www.amazon.com/s?k=energy+suspension&i=automotive&af={"vehicle":"1985-54-653-20--47-8-7-3490--8-2-801---"}&pd_rd_r=ec9a890b-59b2-4eb3-865e-f93b3f1b0f4a&pd_rd_w=sVMuX&pd_rd_wg=ZVXhb&pf_rd_p=9ff8ac19-86ca-4471-91f7-d0c0ecfc7454&pf_rd_r=PX3FVNZJ9SVPEXQB5FNQ&qid=1563058062&tag=viglink1063389-20&ref=sxts_pf_dsk_ftr_2_1_9ff8ac19-86ca-4471-91f7-d0c0ecfc7454
  9. faaiish
    23
    6
    Oct 3, 2018
    GB,
    Just wanted to let you know if you go to villagefordparts.com they show the rear trans mount still available and it is under $20.00 for the factory mount. I just ordered the factory water pump for under $90.00 for my 89
    riphip likes this.
  10. Knuckledragger
    Knuckledragger blowing chunks
    2,128
    103
    Nov 7, 2008
    Pasadena, CA
    https://millerobsoleteparts.net/
    has a lot of old parts and will even talk to you if you cannot find what you want doing an online search through their inventory. They do not have everything, but it is another place to look as our parts grow more difficult to find. It helps a lot to know the part numbers.
    riphip and tbrumm like this.
  11. YJMike92
    YJMike92 Full Access Member
    302
    144
    Aug 10, 2018
    NW Arkansas
    riphip likes this.
Share This Page
