For sale: Complete Hydroboost setup with firewall plate
ksingltn
Anniston, AL
Had this presold before I bought the 88 F-Superduty I am parting out, but that deal fell through. This is everything you need to convert to hydroboost with no parts chasing and fix your firewall at the same time.
Setup includes:
Power steering pump with hydroboost reservoir. Looks to be a fairly new reman. Has V-belt pulley and mounting bracket
Both pressure hoses, pump to hydro and hydro to gear, as well as the hydro to pump return line. Hoses look to be in good shape, with no obvious cracks or abrasions. Return line may be worth replacing, but its just a common hose, no special fittings and it does not leak that I can tell.
Hydrobooster with F-superduty master cyl.
'88 pedal set for a manual trans truck. Custom clutch pedal cover for no extra charge ;Sweet
Firewall repair plate with mounting hardware. This is the one you have to remove the cowl panel to install. One of the holes for the clutch MC is chewed up because the PO did not use a washer under the nut, and the nut pulled into the slot. Should work fine with a washer.
All of the parts work well, I drove the truck about 20 miles home and there was no noise from the pump or any other noticeable problems.
Asking $350 shipped to the CONUS. Would prefer not to separate, and sell all as a set.
Nice looking custom clutch peddle...:rolleyes::rotflmao:thumbsup: I really like how people can think up a repair that works. I'm impressed. Thats a steal of a del. Is that firewall reinforcement plate the one Jason makes. Sure looks like it.
cpdenton
Truck needs paint.
Conway AR
When is swapped my pedals in, I went to the help section at o'reilly at bought some new pedal pads. Think they were 4 bucks a piece or something. That's one of those things that a few dollars makes the truck seem so much nicer than it would just leaving the wore out.
ksingltn
Anniston, AL
$350 is a little steep and this isnt the for sale section
My mistake, thought I was in the for sale section when I posted it. Maybe one of the mods could move it?
As for the price, thats my asking price, I'm willing to negotiate.
freebird01
Post Turtle!
Fort Wayne, IN
doesnt look like it.... the nut plates look like factory ones.
pwillis
