Good to hear Mel.
Glad there is another vendor available.
My apologies again. It's Gunson 77089. I wrote it down to check out later and couldn't read my own writing. It was in a post from June 7 called Timing. Amazon has them listed for just over $100. Right next to an Innova timing light for just under $100.
The only special thing a timing light needs for the diesel application is the adjustable advance on it, as our cranks only have one mark, at 0*TDC. So you need to dial in your advance and you're good.
I personally have a cheap harbor freight meter, and a garage sale snap-on, they both read exactly the same so I'm pretty happy.
That said, the best setup would be to get one with a tach built in too! Then you can do everything from under the hood without needing a helper, and our stock tachs aren't good in the first place.
That sounds like a plan. I'd imagine that getting a light with a tach function that would work for us might be a bit tricky. So the perfect light would have a tach (that works for the idi) and advance. While I'm wishing, let's make the tach and advance visible on that same screen - less than $150 while we're at it
I've got a Ferrett....... it's in my toolbox at work....
Holy ****....... I was going to make fun of your wanting to only spend $150, but here you go you lucky SOB!
ON SALE THROUGH SEARS MARKETPLACE AT $170!!!!!!!!!!!!!!!!!!!!!
https://www.sears.com/ferret-tach-advance-dwell-volts-timing-light/p-SPM5842732801?rrec=true
Look about identical to me...
I was wrong again. I was looking at the OTC 3398 fuel injection pulse tester at the top of the page and thought it was the Gunson 77089. I'm not much of an Amazon shopper. I should have scrolled down a little bit. I tried to help someone and I get everything wrong.Thanks friend! The Gunson is coming up at $250 plus on Amazon...
So I'm confused is the amazon link above a light that works for our engines with the wrong picture? And is it all we need to time them? I know nothing about timing but need to learn
