FEELER 93 F250 IDI 4X4
danman004
IL
Thinking about selling my truck. 1993 F 250 7.3 non turbo 4X4 5 speed. Extended cap Long bed. Has 215000 starts, runs and drives great. Rusty in the normal spots driver wheel opening on bed, fender bottoms, cab corners
Lots of new parts with in last 3000 miles........
Trans rebuild (reverse and 3rd were acting up)
Clutch and pressure plate
Clutch master and slave and new fluid
new fluid in transfer case
front and rear diff fluid change
rear diff new spider gears ( had some slight wear so i replaced them main gear looked great)
Tie rods and drag link
Oil pan
complete brakes brake lines all around calipers and shoes and all
bench was recovered
upper and lower rad hose with coolant flush (with SCA added and
checked regularly)
I know there is more that i cant think of right now but have a huge pile of recipts i can go through to figure everything else out.....Let me know if there is any intrest i can text pics or email
$4500.00
I also have a cummins 12v complete motor and flex plate i was thinking of selling with it. Has 155000 on the cummins came out of a service truck that was fleet maintained. Pump, turbo, intercoller, etc its all there
price with cummins 5500.00
93_444idi
first on race day
missouri
would be interested in the cummins itself, I have no need for another idi though. what year 12v?
danman004
IL
I was looking for 1500 for motor only. get a better deal if you buy it with the truck. Yes it was a running motor i was told the truck got Tboned in the service bed and was to far to be repaired. I may want to wait a little while to see if i cant sell the pair...the cummins might be a selling point for some.....Un less you want to buy both and then re sell the truck.
93_444idi
first on race day
missouri
i cant afford both, just considering doing a 12v swap instead of building an idi. Just let me know when you decide to sell em seperate if you can't sell em together.
danman004
IL
do you have an email i can send you some pics later....Normal rust but not like most of them.. Cab corners, a little at bottom rears of fenders and driver side of bed (wheel opening and rear bed corner only) doors are good floors are solid. Seat was recovered carpet was samhpooed 4 times still some stains but clean. No leaks what so ever. lots of new parts. Clutch is stock. could use a replace ment that was next on the list. Slips a little in 3rd gear.
pwillis
