jaluhn83
Dumb question, but are you sure you're turning it the right direction? It's reverse thread. I've certainly done similar things a time or 2.
I would try to put heat on the fan clutch nut and use a big hammer. It should come off.
Honestly not sure you can pull the water pump with the clutch on - IIRC the pulley covers a couple of the bolts and you can't get the pulley loose without pulling the fan clutch.
