94turboidi
I rebuilt my turbo from my factory 94 idi turbo engine and put all of it on my 1990 engine. It picked up some power but it has a exhaust leak. I can't pinpoint it. I think it might be around the y connector on the passenger side. I took it all apart awhile back and put some exhaust putty on it to try and seal the slip joint fitting but it was the same.
I have the transmission out of the truck right now doing a clutch, welding the flywheel, rear seal, master/slave cylinder and misc. things and want to fix this leak. My gear shifter boot is bad and it will leak exhaust fumes into the cab sometimes! Anyone have any leak similar to this? It never leaked on the other engine. Also where can I get the rubber hose that goes from the valve cover to the intake? I used regular hose and it kinked and seems to be making oil leaks. I would like to get the pre formed one that the factory had.
The reason I believe it to be on the boost side is I rarely hear the turbo whistle and its only for a few seconds, I don't have gauges but I don't think its making much boost.
