1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Fabrication/ Fishplates Question (with pics!)
Discussion in 'Lounge' started by idiTravelAll, Jun 30, 2020.
  1. idiTravelAll
    idiTravelAll Full Access Member
    252
    73
    Sep 2, 2017
    Gilbert, AZ
    hopefully this is off topic enough to be in the lounge, had my frame shortened a few weeks back and I've got a welder coming this weekend to plate the frame, weld in a new xmember, and new body mounts (those are going to be fun, both width of frame and body mount holes are exactly 38")
    Well we planned to step-cut or 'Z' cut the frame but we had to take too much out and it wouldn't have worked out so we had to do a 45 cut, even with a 45 cut we could not have taken another inch out.. nevertheless with the cut and all that's going on in this area I'm confused how to place it properly. Frame height is 8" so I'm kind of leaning towards a 6" round plate. What are your thoughts? Id rather plate the inside since the frame will be pretty visible but I'm not really seeing how that's possible either.
  2. riphip
    riphip Supporting Member Supporting Member
    764
    222
    Nov 16, 2005
    Memphis, TN.
    I would grind out where the bracket was cut off (shortest one) and weld in a 1/4" diamond over the center of the cut. If you can, reinforce under or over top cut. Probably stress crack there first if it is gonna.
    idiTravelAll likes this.
  3. idiTravelAll
    252
    73
    Sep 2, 2017
    Gilbert, AZ
    If this guy can get that brace out we will definitely go under, you don't agree with the circle plates? I thought diamond plates were more for a step/ z cut due to being able to cover the entire horizontal seam/ weld?
  4. riphip
    764
    222
    Nov 16, 2005
    Memphis, TN.
    You do not have to cover the whole weld/seam. 1/4" thick Diamond will spread the stress. Your weld looks good from here.
  5. idiTravelAll
    252
    73
    Sep 2, 2017
    Gilbert, AZ
    I'm sure we can whip up some diamonds but what's wrong with circle plates? I already had the guy thats going to finish this cut them in 5 gauge to match the frames thickness.
  6. riphip
    764
    222
    Nov 16, 2005
    Memphis, TN.
  7. idiTravelAll
    252
    73
    Sep 2, 2017
    Gilbert, AZ
  8. idiTravelAll
    252
    73
    Sep 2, 2017
    Gilbert, AZ
    @riphip hows these looking :Thumbs Up
    chillman88, DaveBen and u2slow like this.
  9. riphip
    764
    222
    Nov 16, 2005
    Memphis, TN.
    You won't have to be concerned about that repair:Thumbs Up:Thumbs Up:Thumbs Up
    I love a MIG when you can't have a TIG. Nice and clean
  10. idiTravelAll
    252
    73
    Sep 2, 2017
    Gilbert, AZ
    Right on thanks for the confidence boost, I knew it looked pretty good but I'm never sure how good.. even the frame job I wasnt super confident about knew it looked pretty good. Welded some strap on the top frame rail at the splice.. body is setting on it because i still need to fine tune positioning and drill holes through the new body mounts so there's no bushing in there right now.
    riphip likes this.
Share This Page
