My1500DollarTruck
I replaced both sending units from this vendor here, worked fine.
https://www.ebay.com/usr/trexautoparts111014?_trksid=p2057872.m2749.l2754
pickup tubes:
https://www.ebay.com/usr/swagperformanceparts?_trksid=p2057872.m2749.l2754
Wired the sending units to their own gauges. You can wire the white/color stripe wires and black wires from the sending unit together and the stock gauge will read empty all time , or dont wire them and it will read full all time. Either way since its no longer being used. NOTE: if you go this route with independent gauges , you need to match the OHM range of the sending unit and the gauge as close as possible to get a correct reading.
pickup tubes:
