exhaust manifold cracked
jperecko
Diesel Ape
Boonies of SoCal
The one that is just cracked... I would consider trying to weld it but I guess a new one is not too expensive and the hassle of changing it is the worst.
What causes these to crack or get damaged like this? Just physical abuse of somebody pounding on it? Running the engine too hot? Cold water on hot pipe?
Ironman03R
Risingsun, OH (NW OH)
I just noticed one of mine is cracked when I got home from the rally, the white color helps show off the little black lines LOL
The driver side was replaced right before I got the truck and if I remember right its the side that is cracked again.
NJGearhead666
New Jersey
cast iron fatigues from all the heating and cooling it does the manifolds paint only lasts a year before its flaked off and manifold starts rusting so its a few things that cause it. also welding cast iron dosent work. as the weld beings to cool it contracts and will cause cracking in another area.
jperecko
Diesel Ape
Boonies of SoCal
I know it is possible to weld cast... not sure about cast heads though because of the heat changes...
NJGearhead666
New Jersey
it is possible you have to heat the cast piece to aroud 400 degrees. you can also do this to make repairs to cast heads. the manifolds are no where near the thickness and metal density of cast heads or a cast block. plus the best way to weld cast is to tig weld it to control the heat better. but to go threw all of the trouble of taknig the manifolds off the truck to just weld them is not worth it. just get new and call it a day.
spencergt66
Edmonds WA
yea I'm just going to replace it for 100 bucks its not worth trying to weld and reinstall plus if the piece is distorted from welding afterward then it can be a pain in the ass to get everything to line back up
spencergt66
Edmonds WA
Got some pics of my down pipe here man, man who ever did all this exhaust work from before did a really cheep nasty job so i just cut it all off still can barely here the turbo though pry cause of the exhaust leak I'm guessing but I'm pretty sure the down pipe isn't stock it measures 3" on the ID
spencergt66
Edmonds WA
o really? i was just kind curious as to what kind it was im going to have to have a muffler shop make a new bracket for it cause it seam to be rubbing slightly on the transmission bell housing good to know though guess i wont have to look around for a down pipe then:thumbsup:
spencergt66
Edmonds WA
well looks like Im finaly going home so this weekend ill have some time to fix my exhaust manifold I also bought a 5" exhaust system pry going to have to modafy it a bit to get that to work but no big deal I also got some new gauges comming so we shall see what kind of numbers the truck will actually put out im just glad to finaly be leaving africa I hate this place
pwillis
