Engine locks up when turned over slow by hand?
inyoyote
Bishop CA
Well when I had the engine on the stand I turned it over by hand many times and had no issues. It had no IP and was upside down. Now with the engine sealed back up and right side up, still no IP, if I turn it over slow it locks up when turned clockwise from the front, there are no glow plugs installed so its not compression.. If I turn it CCW it goes smooth. If I turn it CW fast it doesn't lock up. This is all by hand, haven't tried it with the starter motor yet, Im scared. I stuck the IP back on but haven't tried to turn it over yet. Im hoping the IP gear is catching on something since its not being carried and is just kind of flopping around. Any ideas?
The history of the motor is its an 85 van motor that supposedly has 85k on it but I bet its 185k. It still has decent cross hatching on the cylinder walls, and the rod and mains look good so I'm not to worried. It hasn't run in 8 years and was stored in a garage with just a rag on it intake manifold. I pulled the intake to check out the valves and everything looked good so I put on a new valley pan and sealed it back up. I also resealed the valve covers, changed to truck and resealed oil cooler, rear main, oil pan, new water pump and new lift pump. When I dropped it into the truck is when I discovered the engine locking up.
Ruger_556
Ferndale
Are you sure you're not just coming up on compression when you're turning it by hand?
yARIC008
Drives really slow
Orlando, FL
How slow are you turning it? When it stops, are you able to increase torque and continue moving? When you had it on the stand, were you cranking it over slowly with the heads on it aswell? Did you use the headgasket alignment dowels?
inyoyote
Bishop CA
If I turn it as fast as I can by hand, it is not a problem. If I just roll it over like normal it locks up. When it stops it takes a lot of force to reverse it. I have about a 14" ratchet I was using to roll it over, and to reverse it I have to use a 36" pry bar on two sockets on two pulley bolts, or it will just loosen the harmonic balancer bolt. I never pulled the heads.
I want to just put some oil in it and see what happens with the started motor. Im thinking since its been stored so long, all the oil has drained out and something is catching due to a lack of lubrication. Im just scared it might seize for real this time, and do some internal damage before oil pressure builds up. I would try this with the glow plugs out so there would be less stress and turn faster.
junk
Paullina, IA
I Think your right on with the IP gear binding up on something. Possibly the tach sensor? I would try it with the IP installed as you have and see what happens. I think it's going to turn over. My only concern is as you turned it over with the IP removed. Is it possible that the IP gear jumped a tooth and could be out of time? IDK.
inyoyote
Bishop CA
I asked a question about that here earlier and after some searching, I found a page from IH that said its not possible for the IP gear to un-mesh with the gear cover in place. I also tried to wiggle and turn it by hand and was unable to get it to skip a tooth.
Im headed down to try it here in couple hours and Ill report back. I was just hoping some body would agree with me and not have some terrible news I already did damage, although I can't imagine what I could have done. Thank You
Hmm...this sounds interesting and a lot like a head gasket set is in order...
How where the Glow plugs when removing? Did any have missing tips?
If stored as long as you say maybe some water got in and rusted a bore.
Hmm...watching this one close!
inyoyote
Bishop CA
The glow plugs were OK with only some Kroil I had put on the cylinder walls before I tried to roll it over. They were a tad swollen(autolites), but not enough that I couldn't pull them by gently turning and pulling with pliers. I rolled it over until the exhaust valve was open on each cylinder and put shop air in through the glow plug hole to blow out any debris. The cylinder walls look great with some cross hatching still visible, no rust at all. I was able to roll the engine over as much as I wanted(several complete revolutions) with it upside down. I am confident the problem is not in the bottom end. Im afraid a lifter is possibly binding up, holding up a valve, and interfering with the piston, but i don't understand why it would roll fine upside down but not right side up. The only thing I know of that could move when upside down is my formerly unsupported IP gear. Thank You.
Have you removed the heads?
Sounds to me that this is an issue where you may have to go a couple steps backwards to go a few more forwards sorry to say. the level of binding you are describing is more than I would be willing to allow and NOT tear that down if it was mine to at least a short block level of disassembled, meaning no pan, no heads.
However others may chime in...
Al
inyoyote
Bishop CA
I have not removed the heads. I had the pan off and checked the rods and mains and cylinder walls and cleaned the oil pump. Im not sure what a could see with the heads off that I can't see through the Intake and exhaust ports with my bore scope, which showed no rust on the valves. I also put it down the glow plug ports and wasn't able to see any damage to the piston tops.
Im trying to get this thing going asap, and ordering the head and timing cover gaskets won't allow me to try to get it going this weekend. I agree its a lot of binding, which scared me enough to post the question here. Im headed home to try turning it over with the IP installed and I'll report back as soon as I find out. If it still won't turn over it will be coming back out for a complete tear down. I'll report back in a couple hours.
I greatly appreciate everyones insight on this issue, Thank You all. Ill let you know what happens.
As a quick aside does any one know the napa part # for the fuel filter on the driver side fender? I know I saw it on this site somewhere but I don't really have time to go searching.
vegas39
las vegas, nv
I had a scary issue like this when we put my new head gaskets and new pushrods in my engine. The ebay seller sold me the wrong pushrods, they were too long! Thank goodness I turned the motor over by hand first and discovered it before hitting the starter. They were powerstroke pushrods.
wildman7798
Great Pacific NW
Are you looking for the aftermarket spin on bracket and the wix or baldwin filter with the drain on the bottom? I did away with my factory setup on the firewall and read and followed the upgrade with new parts. Mine was leaving a puddle of fuel on the ground every morning and I am sure the relief ring was allowing air intrusion. I can find you the aftermarket P/N's to replace the system but have no idea if you want to stay factory.
inyoyote
Bishop CA
Thats a good testament to why I always turn an engine over by hand before I even think of hitting the starter. Good catch, luckily it didn't cost you too much headache.
I looked at it closer and realized that it isn't the type of filter separator I am used to. At a quick glance it looks like there is a spin on filter on the bottom. Thats the imaginary part # I was looking for. I will probably eventually convert to a aftermarket setup like you did. For now I will stick with stock until I get some other loose ends squared away. Thank You. I will contact you when the time comes for the conversion.
inyoyote
Bishop CA
Well folks after I installed the IP I again attempted to turn the engine over and viola, it spins freely. So for future reference if your IP is out and you try to turn the engine over, you may run into some resistance. Ok, a lot of resistance. But don't freak out until you re-install the IP and the resistance continues, then you forgot something or have real problems.
I got the IP hooked back up and installed a fuel injection kit and she sparked right up. I only let it run for about 30 seconds as I don't have coolant back in it yet but it definitely ran. It was a little rough and puffed a little white smoke, but it started pretty easily and built oil pressure fairly quickly. Here is a video.
http://s557.photobucket.com/user/inyoyote/media/2013-11-15_14-32-54_865_zps270f74df.mp4.html
The sound is terrible, It sounds like a little bit up a chuff in the intake but I'm not sure yet. I didn't leave it running long enough to know if its still got a little air or if there is another problem. Im hoping the local napa has the upper and lower radiator hoses I need so I can get some water in it and let it run up to operating temp. I also need to get it to the local diesel shop to get the timing set. Hopefully with a little running time it will smooth out, I really don't want to tear it back apart just yet.
A BIG Thank You to everyone who helped me with my questions in this thread and my others on this site. I don't know anyone who has worked on these things, and while the local diesel shop is happy to answer questions, they want $95 an hour to sit and talk. I know I'll be back with more questions. Thanks again.
JunkCowboy
