1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Engine knock, help!!
Discussion in '6.9L IH & 7.3L IDI Diesels' started by Mathieu Gilbert, Oct 11, 2018.
  1. Mathieu Gilbert
    Mathieu Gilbert Registered User
    Oct 11, 2018
    Canada
    Okay, I recently bought the 7.3 idi (because where I live, they don't have taxes because they are old.) Anyway, when I start the engine, it sounds fine. There is no "huge knock" when I rev, it's quite a small knock. However, when I engage the transmission, there is knocking coming from the driver side. If I press the pedal it knock even louder, but it stop when I remove my foot from the throttle. This is killing me, could it be a rod? Injector? Manifold leak? I can't seems to figure out myself. I need your help guys!
    Oh I almost forgot, the temp never seem to go higher than the minimum (it start below the minimum)...
    Also, a guy here posted a video of his truck and mine is doing the same sound (but it's more quiet than his without an engine load)
  2. riphip
    riphip Supporting Member Supporting Member
    495
    95
    Nov 16, 2005
    Romans: 12-21 Memphis, TN.
    Pull the driver's side valve cover & check the push rods and rocker arms.
Share This Page
