electric fuel pump for wmo?
slideordie
i was curious if an electric fuel pump would work for filtering wmo? i was going to setup up a couple filters for it to push through but i didnt know if an electric feul pump would have enough grunt to push it throught the filters or if it would hurt anything or what would happen? just wanted some opinions so i can get my filtering setup going with how these fuel prices are.
MARQ2277
caldwell, idaho
You know, I have the same question. I was looking at a Airdog and Super Dog by Raptor High Performance Pumps. Check out www.pureflowtechnologies.com
877-go diesel
877-463-4373
Marq
_________________________________
1990 Ford F-250 4X4:
7.3 IDI with 120K on the clock:
ATS Turbo with waste gate:
Stage One Injectors (Oregon Injector Service):
Complete Return Fuel Kit (Oregon Injector Service):
DB2 Pump, cranked up with Cold Advance wired permanently on:
4” down pipe, 4” straight through exhaust stopping between cab and bed (no **** on my stuff):
Torque Converter Lock Up Switch (On/Off/Lock-Up):
E4OD Line Pressure Controller (adjusted to fast/firm shifts):
4” lift w/Rancho shocks:
Big Fat Tires on custom rims:
Tows 1985 fully loaded heavy 28 foot RV (my house) everywhere:
69dieselfreak
well that nice
rimrock arizona
thats a damn good question is this for an outside filtration set up or for all ready filtered fuel going to the injection pump
if its for out side set up id say no because i tryed one and i burnt up the pump and it was a vane pump
MARQ2277
caldwell, idaho
I was thinking about an outside set up, for making fuel. Taking some electric fuel pump that could handle the viscosity of used motor/veggie oil, and either push and/or pull the fluid through enough filters to have a finish product to run in a IDI truck. I have written to two (2) companies, and asked them abut their product, and what I had in mine. Right now I am waiting for a response. I will share it, if and when I hear from them.
Marq
_______________________________________
69dieselfreak
well that nice
rimrock arizona
air psi is works better to push oil through filters than and electric pump but i dont see why it might of burned up my pump unless i got a bad one but i got it replaced though
Papabear
Papabear
Grande Prairie, AB
i am just going to use a 12V 15gpm pump and transfer from a dirty tank to a clean one than to my truck because the clean one is going to be on my truck than i can gravity feed from my onboard tank to trucks fuel tank i am going to use a pre-filter/water seperator than a fuel filter both "RAYCOR" style originally designed for aviation fuel.
MARQ2277
caldwell, idaho
Raycor? That sounds cool. I'd like to know more about the Raycor, do I just google the name, or is there a company I should know about??
Marq
Exekiel69
I would stay away from 12v pump for filtering, I rather use a regular 110v pump or even use compressed air in a tank that will be much faster and provably effective.
69dieselfreak
well that nice
rimrock arizona
id agree it really ******* the pumps to try to push or pull them throught lets say 2 filters 10 mic or a 2 mic its just ******* them
i use air psi and its efective and really simple to set up
MARQ2277
caldwell, idaho
How does that work?? Pushing fuel/oil, how would you do that?
Marq
69dieselfreak
well that nice
rimrock arizona
what i do is fill it through my pump and shut a valve to to the pump pressurize the tank 20psi open the valve to my filters and there you have it ;Sweet fuel
William88
