Egt questions
shawn deere
nebraska
That would really help as I'm not a big fan of the black smoke. Gets all over stuff.
Word of advice on the passenger side exhaust manifold you need to remove the studs that bolt to the Y pipe. Factory N/A has a sholdered stud there that wont seal up the the turbo Y pipe. Real PITA.
As for mine, I bought the running 7.3 that's in my 85 F250, an almost complete first gen Banks, and had it delivered about 150 miles for $950. Russ has done the mods to it. I have my intercooler, piping, and just about everything else I need to install it. I pulled the engine out on the 4th to reseal it. The heads are going to be going in for a valve job after I get done porting them. My Typ4 cam from Russ will be going in along with head studs. It will be a little while before I get to drive it, but I'm sure it will be worth it!
Fordfan90
Idaho
Dang sounds like it should have some power after that. What kinda of power should I expect from a turbo?
shawn deere
nebraska
I think @Macrobb tested this. Factory turbo r and d 110cc injector pump 250rwhp. Iirc
Factory turbo, fresh injectors and fresh ip i think people are hitting 200 rwhp. N/A is around 145??
Macrobb
North Idaho
Yup, factory turbo OR banks wastegated(te06h) turbo, both do about the same.
If you do get a 110CC pump, make sure to get a Hypermax Smoke Puff Limiter with it. It controls fueling with boost, keeps you from smoking off idle, and really helps the low-end acceleration.
Pretty much
N/A is around 145??
That's being generous. this article claimed 135 RWHP on a just-broken-in 92 truck.
I've seen one NA IDI on a dyno locally(2,000 ft elevation). It made 85(!) HP, and yes, the owner had cranked the fuel up.
So... compared to NA, it really makes a difference when you need the HP.
I find that unloaded, the 0-45 MPH time is about the same. The turbo barely kicks in, doesn't really affect it much.
45-60 or 70... it makes a difference.
Loaded? The more load, the bigger the difference.
I personally wouldn't attempt to haul a trailer with a NA IDI except in an emergency... you'll be going really slow.
With my 250RWHP IDI? I've hauled 9k without issue and kept up with traffic, going 75 on the freeway.
pelky350
Springfield, OR
It only too me like half a day to install my 088 turbo, and only half day to install my factory turbo lol
