Eeek!
jaluhn83
Upper Marlboro, MD
Took my backhoe up to my folks house last weekend - this was the last part of the move I've been doing the past month. 21,200 GCW which is nothing to laugh at. The truck did very very well - towed like it was heavy, but totally stable and handled well. Held ~40 mph up Cajon pass and other hills (max of ~5% grade?) and was able to easily do 55 on the highway. I was very happy with how she did....
Till I got home and got a pretty good shock:
:eek::eek::eek:
As near as I can tell, the left rear nut got loose and fell off somewhere along the lines, which then caused the center left flange to break clean off and was well on the way to taking the rest of the mounts out.... right rear flange is badly cracked and not far from failing, which undoubtedly would have been shortly followed by the right center and the trailer tongue hitting the road.
Admittedly, I had somewhere near 1800lb of tongue weight, so the hitch was at or over it's rated load, but I think it would have been fine had the nut not departed from it's indicated local. Probably going to get a new class V hitch to replace it - pretty sure this was a heavy class IV.
It's also been interesting to see how well these trucks handle this kind of load. Even with a very heavy bumper pull trailer with a lot of tongue weight the truck never acted light on the nose at all. I was at or slightly over truck GVW (8620lb with one tank empty and no driver), almost all due to tongue weight and even then she was rock steady. Went from 34-3500lb on the front to 3100 - nice to have that heavy diesel up front.
kas83
Plover, WI
I've always been happy with the performance of my IDIs while towing. Severely overloaded or per the book, they always seemed very stable and up to the task. Never set any speed records doing it, but was always safe.
I had the cross tube on a class v break one time, approximately 6 inches from the receiver itself. The hitch had minimal surface rust, didn't seem compromised by any means. Luckily happened while loaded a heavy vehicle, so no issues while driving.
Sent from my SCH-R760X using Tapatalk
A good reason I don't like hooking safety chains to the hitch point.
Had it broke loose, bye bye trailer.
Sent from my USCC-C6721 using Tapatalk
jaluhn83
Upper Marlboro, MD
I agree with that one..... on the other hand, if you don't hook them to the receiver what do you use? Weld something custom to the frame?
Looking at this one, I'm pretty sure that nothing too bad would have happened - the front 2 bolts would probably still be there, it'd just drop and drag the trailer. Be a big hitch in the plan, but probably not cause a serious wreck. Still scares the snot out of me though.
One of the reason I like gooseneck trailer much better.... on the other hand, I already have the bumper pull and it works very well for what I use it for - occasional short to moderate distance trips.
Yeah, just something else on the frame.
I'm sure you've hauled that thing a lot, but IMO, looks like you were too far forward.
jaluhn83
Upper Marlboro, MD
Probably got a good point there, may try to do that when I replace the receiver.
Actually first real time I've moved the hoe. First time was about 15 miles and it was broke so just getting it on was hard enough. Probably a bit further forward than was optimal, but that's about what I wanted. The last heavy load I took (20 ft container and junk) 2 weeks before was loaded too light on the nose and did a real nice job of trying to wag the dog anytime I went over about 45.... after 250 miles of doing that the last time I was intentionally going for a nose heavy load. Figured possibly overloading the rear tires/axle was reasonable to keep the rig safe, and doing it very occasionally and going slow shouldn't cause much wear on the rig. As it was, it was right.... except for the missing nut anyway.
That backhoe is misleading though too, since the center of gravity is further back than you'd think - right around the front of the rear wheels or just a bit forward. Looking at the numbers, I had 12,640# on the trailer tires and best guess around 1800 on the tongue - that's 12.5% tongue weight. Certainly it was somewhere between 10-15% tongue weight, which is what everything I've read indicates it should be.
thx997303
utah
Ha, your hitch breaks loose all the way you're screwed no matter where your safety chains are. Had it happen, it aint pretty.
Had the exact thing that the OP experienced with an old Chevy I had once.
That trip wasn't fun.
I drove 100 miles south to Delta, UT to pick up a 56' Willy's pickup. On the way down, I managed to spill gas on myself. Figured it wasn't a big deal, but about 5 miles down the road my crotch was on fire. Ran like hell into the bathroom at a gas station and cleaned up. Mild chemical burns from that.
Figured to keep going. Got to Delta, bought and loaded the Willy's without an issue. Halfway out of the desert heading back, and I started smelling burnt rubber.
Pulled into Nephi so my brother could visit his girlfriend, and when we went to leave, I got a block away and a horrible screeching sound happened accompanied by a jerk of the engine. The alternator belt had snapped.
So I start the truck, and park it at the house we had been visiting, and get a ride from my Brother in law. Head back the next day to change the alternator, since it had seized, causing the belt problem.
Started the truck up, heading the remaining 50 miles home. On the freeway the trailer started swaying like crazy. Was pulling that old half ton chevy all over the road. Once nearly pulled itself into a semi. Would not have been good.
Puckered up and fought the truck the whole way back after checking everything out. It all SEEMED fine at the time.
Get home, and the next morning I go to get a battery in the Willy's. Get a block away from home, big clunk. Get out to check, and the trailer's tongue is lying on the ground, with the hitch still attached.
Called my friend up, and he brings his work truck out. We lifted the tongue of the trailer with a hi lift jack, on a steep slope and managed not to die. Then we hauled the thing back to my house and parked it.
Turns out the bolts had loosened just like the OP's had.
Crazy stuff. Glad it wasn't worse for ya.
Too much tongue weight can actually take too much weight off the front end. Steering will feel real light.
Most of the weight seems to be in the hoe arm.
When loading, basically should try to keep the trailer level, by positioning the load.
Screwed no matter where the chains are? Yes and no.
Yes, because it's still gonna be a bad day.
No, if you have proper safety chains for your trailer/load.
Your chain/s is supposed to be rated for your gross trailer weight with load.
At least you could keep control of the trailer, vs it coming completely loose, hitting and oncoming car, killing everyone inside. Then you'd be in prison for manslaughter. All because of faulty equipment.
Wyreth
Certifiable Noob
Las Vegas, Nv
Of all the horrible things that happened during my move to Vegas, I'm really really really really glad THAT wasn't one of them.
I think I will just add the hitch hardware to my pre-haul checklist.
thx997303
utah
I can see your thought process here. Though I think manslaughter charges would likely be a stretch.
Being able to haul these weights is not the issue with our rigs. Its being able to SAFELY STOP THE RIGS... I'm surprised chp didn't site you had they seen you. So for others reading this post. Will you be checking the hitch bolts as part of any pre hauling trick no matter the weight of length of trip... I know I sure will. Being over safe is not something anyone can do.
jaluhn83
Upper Marlboro, MD
Thx, I think someone upstairs really didn't want you to get that Willys... :hail
79Jasper, I agree with you about light steering - had that happen before. That's one point I was making though - having that nice heavy engine makes it much less of an issue.
Not sure I agree with using the trailer being level as a gauge of load - that's more dependent on the hitch setup and trailer being setup right. Ideally yes it should be roughly level loaded. I tend to look at how much the truck squats in the rear as a gauge of tongue weight, and I prefer to error on the side of too much tongue weight - I know the truck can take it and erroring the other way is worse.
Agree with the proper safety chains. Haven't seen too many folks that have independent frame mounted safety chain connections though - seems like pretty much everyone goes to the receiver. Not that I don't think frame mounted is better, just that it doesn't seem too common. Makes me wonder what the law actually says and how the court would take it if there was an issue due to a receiver failure and the safety chains were attached to the receiver.
Agree with stopping too - hauling too much trailer with too little truck is one of my pet peeves. This is somewhat over what I really would prefer to haul with the truck - I feel like ~18k is a good max ballpark GCW. But for a once a year type evolution is seems reasonable safe when done cautiously. I also have brand new trailer brakes on the rig - one of the first things I replaced on it. And hydroboost on the truck. Would have been hairy stopping with no trailer brakes, but still safe. As it was I had no issues stopping on controlling the rig.
And yes, hitch bolts are now for sure on the checklist. ;Really
Time to take a page from the commercial book...When hauling heavy being like a semi...do as they are required to do..
PRE TRIP inspections including brake checks etc. SAFETY isn't an accident..it's prevention of an ACCIDENT!
NUFF SAID
Oh ya...WOW that looks super scary.
Can30Diesel
Agassiz BC
I didn't want this happening to me, so I overkilled my mounting hardware. I've got 1/4 inch steel plates sandwiching in the receiver and the frame together. Then I have thick wide washers, lock washers and double nuts with loctite on the grade 8 bolts and I still check it throughout the camping season to make sure nothing has worked loose. :)
MechDiesel
