Econoline fuel gage issue
NTOLERANCE
I'm the cotton swab
cottage grove, wi
The fuel gages dont work on my new e350. Previous owner replaced the fuel selector valve, and claimed they stopped working few months afterwards. Anyone got a schematic or a place to start?
yARIC008
Drives really slow
Orlando, FL
I would check for loose connectors. If the connector wasn't pushed together all the way then there's potential it worked at first then a hard bump knocked it apart. Happened to my fuel gauge once. I went around without for like five years until i just came upon it by accident one day and pushed it together all the way.
idi_econoline
No Bed For Me!
Northern California
I expect you'll find, NTOLERANCE, that (as with Fs) the fuel gauge is the most reliable of the 4 in your cluster. Apparently, different-looking cluster, equipped with the same junk gauges.
Got ISSPROs and a pillar pod patiently waiting. Got an exhaust valve to fix first.
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Are the two studs on the back of the gage the input terminals to the gage? If so i have a constant 12.2 ohms there and zero volts, telling me the circuit is open.
I checked the connector on the selector valve,, pulled it down, cleaned and reconnected....no change.
ridenby
