FORDF250HDXLT
The heater core loop is a bypass.It's sole purpose is to provide heat in the cab.The primary engine cooling route is through the block,pushed out of the upper radiator hose via a water pump,through the radiator and returns to the block through the lower hose.The heater core loop is a secondary bypass loop,not designed to provide any additional cooling.Therefore,if you bypass the heater core loop with a coolant filter setup,your bypassing the bypass.
.........but it doesn't hurt anything.
