nightrunner84
When sitting in line at a drive-through, I put it in gear to pull away and it wouldn't move. Forward or reverse. It kinda tried, but the engine just revved, and it barley moved. Someone helped me push it out of line, and while it was rolling down a slight incline, I hit the converter lock-up switch that I put in a few years ago. The bogged the motor down almost to stall, but I could make a loop in the parking lot and put it in a spot. That was definitely first gear, not second (limp home). Also, the fluid level is correct. Also, I tried putting is in first and second with the shifter, no difference.
It must have hydraulic pressure to be in first gear and not second, so the pump is OK, and the TCM is getting power?
So, I think there's something going on with the stator, impeller, or turbine inside the torque converter. Does this sound logical? I'd hate to put a converter in it, only to find out it was something else.
