Jake9473
Hello all, I am new to the forum.
First off, I have a 1994.5 f250 7.3 powerstroke. I bout the truck last August with it needed a Trans.
The Trans was rebuilt, but had no manual 1st gear, and when placed in drive started out in 3 rd gear. Will not shift on its own. That guy wouldn't warrantee the work because he said it was electrical. I fixed a wire off the solenoid pack plug that was chaffed, I also put a new shifter and od off switch on it because the wires were ripped out. Still same issue. I undid all the wires in the loom from the transmission to the relay on the drivers inner fender and cleaned contacts. Also replaced
Both relays.
I then took it to another transmission shop on September of last year, and he told me the transmission needed to be rebuilt, because the other shop butchered it. So I paid the piper and had them "rebuild" it. After having my truck for 3 and 1/2 weeks he called me and told me that the ECM was bad and that it needed a new one and needed to be flashed. So they did that and called me the following day and said that it still was still not shifting on its own, but I had manual first gear, and that I needed to come pick it up because he didn't have the room in his lot to store it but told me it had all the gears on the selector and to manually shift it until he could get it back in the shop in a week or two. When I came to pick up the truck, I noticed that when you place the selector In first gear take off and need to shift there is no difference between 1-2 on the dash. You can definitely feel the 2-3 shift but those are the only two gears. That was October 2014. Fast forward to 2 weeks ago. After calling every week since October finally got the truck in and he said he would get right on it. Low and behold the truck hasn't moved since I took it there and he dropped the pan and checked the valve body and valve body gasket as well as the accumulator body to make sure all the wormholes were the same. IN THE SNOW.
He called me yesterday and told me that the solenoid pack wasn't getting power to one wire and that they were going to bypass it with a "jumper". I called today and he told me that was done, but the solenoid pack still is not getting power.
I talked to the previous owner and he informed me that he only had 2nd and third gear and he quit driving it after it quit moving ( welded the forward clutches together from over heating with a Trans line leak)
WHAT GIVES?
I have speedometer and tachometer and they read true and I have exhausted my patience and my wallet.
And. No other forum has been able to help me whatsoever.
Both relays.
WHAT GIVES?
