This may be somewhat long but I want to be as thorough as I can be.
I had been dealing with an intermittent issue with the tachometer not working in my truck on cold start up that would normally start to work after the engine had been running for a few minutes. From what I have learned now, the TECA unit was not getting power during this time because all I had was reverse, 2nd and 4th gears when it acted up like this. This had been going on/off for a couple of months.
For the sake of time I had a shop (that I do trust) diagnose what was going on, and they discovered that the TECA relay was bad, some wires had been chewed up by a rat near the TECA connector (which was fixed properly, I did inspect the work), the pigtail harness that plugs into the solenoid pack on the transmission had bare spots in the wiring and was grounding out a few of the wires, and that some of the solenoids in the solenoid pack were not in the correct resistance range. They also adjusted the FILP sensor back to spec as well.
So, new TECA relay, new solenoid pack and new pigtail harness was installed and the transmission was working normally. A few days later I'm back with the same problem of no tach and OD light not coming on when I push the button. I diagnosed this problem myself and verified that I had power/ground on the correct pins in the TECA connector and that I was getting my 5 volt reference at the MAP and FILP sensor during this which led me to believe the TECA unit itself was going bad. The old TECA did have a capacitor that leaked out on the circuit board and had started to eat through a few traces so it was already on borrowed time. It was replaced with a reman unit from A1 Cardone and I verified that board was in good order/condition before installing it.
On Monday I had the same problem again with no tach/OD light. Fiddled with the TECA relay and socket and got it to work now and stay working thus far. My hunch is the TECA socket is going out and I'm seriously thinking about swapping in a bosch style relay and socket to get that sorted out. I did verify power/ground to the relay so I know everything up to that point is good which is making me suspect bad relay or bad/worn connections on the relay socket itself.
What I'm getting now is code 62 (excessive TCC slip) and the transmission going into limp mode (OD light blinking, harsh upshifts) after driving on the interstate for a while. I've read the article here written by FORDF250HDXLT but in my case I've already had the solenoid pack and harness replaced. At this point I'm not sure what to do going forward in order to test if the torque converter really is slipping or if I still have an electrical problem somewhere.
While driving on the interstate yesterday evening (after clearing the code) I did try to disengage/engage the TCC solenoid by maintaining 65 on the interstate and tapping the brake pedal to turn on the brake lights which should have disengaged the TCC solenoid for a few seconds before re-engaging it, but I didn't feel it or see it disengage on the tach... I'm going to take it out for another test drive and test it again to see if the TCC solenoid will disengage/engage with me paying much more attention to it.
I love the truck but with this much money into it I'm going broke over it. Converting it to a ZF5 would be nice, but not possible at this point financially so I'm stuck with what I got. If anybody has any ideas or suggestions I'll be open to them. I'll report back the results of the test drive in a few minutes.
Thanks.
Thanks.
